GHW9250ML0 - belt off, pulley misalignment, bearing ok
I have a Whirlpool Duet model GHW9250ML0. Looks like vibration caused the best to come off the pulley. When I reinstalled, it turns out the pulley is loose - it looks like it's supposed to be loose (about 5 or 10 degrees rotation perpendicular to the shaft is built in) but it flops around parallel to the shaft axis. I can't tighten the bolt enough to prevent this flopping so when I start up the machine, the belt slides around on the pulley, making a nasty squeaking noise and pulling the shaft and drum out of balance. The bearing seems okay, but it almost seems like I'm missing a big washer that would allow me to tighten the bolt a bit more. The shaft does seem slightly worn, but not excessively. Any thoughts or experience?
  • wade_lukiano Sep 25, 2009
    DocPlayer, I agree, it shouldn't have that much movement - I guess that was the point of my post. I have removed all the parts, and the problem is, I can't tell what is worn. Is it the pulley? Is it the flat bushing area on the end of the bearing where the pulley touches. Everything looks okay, but I still can't tighten the nut enough to prevent the slop. It's not just poor performance - the sloppy pulley/belt makes the whole house shaaaake on spin mode.
  • 4,340 Answers
No pulley should have that much clearance or movement....Something is seriously worn. Perform surgery and find out what failed.
you will have poor performance until you get this issue resolved and tighten the belt correctly.
Posted on Sep 25, 2009
Belt squell 1995 mazda b-2300 strip down model no ac no p steer
A common cause of belt noise is a misaligned belt run, this can be caused by worn bearings in the various pulleys causing them to run off track from the pother pulleys, also the crankshaft pulley rubber isolator can come apart and the crank pulley walks outboard and this causes the noise.
Sep 20, 2012 | Cars & Trucks
Whirlpool Duet washer...after problem with it getting out of balance due to not draining and trying to spin with a heavy load, I have since noticed if I place my hand inside the tub..it will spin freely...
Your original problem is likely to have damaged the bearings and the spin tub shaft... the shocks can fail, but that would not affect the fitment of the shaft and bearings.
Apr 21, 2017 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
2003 Nissan Altima when I turn on the A/C the belt vibrates alot
Check all the belt pulleys, it sounds like there is too much play (from normal wear, bearings worn) and that is causing the vibrating belt. It would be best to remove the belt 1st, then check for play at the pulleys.
Jul 24, 2009 | 2003 Nissan Altima
Whirlpool Duet model GHW9100LQ1belt slides to back of pulley
DO YOU HAVE THE CORRECT BELT? DO THE GOOVES MATCH THAT PULLEYS? IS UR MOTOR PULLEY ON GOOD? DO YOU HAVE ANY RESTRICTIONS IN UR DRUM /BASKET CAUSING IT NOT TO TURN?
ARE YOU USING HE DETERGENT?
May 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer tub bearing
wow ,,that unit must sound like a jet ..this is a job,,i can talk you though but i cant tonight,,if you can wait i will help tommorow at 6 after work..if you need a little head startgo to cematters.com
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
New belt install
OK your a pro if you attached a pulley correct, now for the belt. The belt is elastic in nature and can take some abuse, so first loop it on the motor and loop it on the top of the pulley, holding the belt with one hand that follows the other hand turning at the same easy speed. it will get real easy a third of the way around and your done!
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
209 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
