Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
I can not activate it received by fax saying that dr conected mode and as it is or disconenect
komguy
  • 2306 Answers
SOURCE: MFC 465 CN - says FAX in DR Mode...What is that?
DR mode is distinctive ring, you have to go into fax setup and step through the options. If you go to print reports and select user settings the report will tell you what it's set for and the options are found in the same order they are printed.
Posted on Jun 24, 2009
  • 4 Answers
SOURCE: I am unable to receive fax. I have tried to fix
try this go into maint. mode * 2 8 6 4 quickly. then hit 9 twice. it resets with out losing any quick dials or tti
Posted on Apr 12, 2010
Jimsta01
  • 405 Answers
SOURCE: can't set mode to receive fax
DR MODE is in use means that your machine is setup with the distinctive ring feature, to turn it off follow the directions below.
Turning off the Distinctive Ring
1 Press Menu/Set, 2, 0, 2.
2 Press ▲ or ▼ to select Off.
Press Menu/Set.
3 Press Stop/Exit.
Then you will be able to change the receive mode.
Posted on Apr 17, 2010
SOURCE: fax is stuck on manual mode. how can I change.
I had this problem too, I just fixed it! DR = DISTINCTIVE RING, this means you have it turned on. To turn it off go to menu, fax, miscellaneous, distinctive and select OFF. Now go to back to initial setup and select your mode!
Posted on Apr 21, 2010
dss902
  • 16 Answers
SOURCE: I cannot set my MFC 8460n to receive faxes - it
The machine is set to Distinctive Ring mode.
Turning off Distinctive Ring
Press Menu, 2, 0, 2
Press a or b to select Off. Press OK
Press Stop/Exit.
Posted on Mar 05, 2011
My fax machine will send a fax, but I can't receive a fax?
The fax machine may be in secure receiving mode. The following is from the User's Manual section on Faxing. downloadcenter samsung com
Receiving in secure receiving mode
You may need to prevent your received faxes from being accessed by unauthorized people. You can turn on secure receiving mode to restrict printing of received faxes when the machine is unattended. In secure receiving mode, all incoming faxes go into memory. When the mode is deactivated, any stored faxes are printed.
Activating secure receiving mode
  1. Press btn_fax.png(Fax) on the control panel.
  2. Press Menu until Advanced Fax appear.
  3. Press the left/right arrow until Secure Receive appear and press OK.
  4. Press the left/right arrow until On appear and press OK.
  5. Enter a four-digit password you want to use and press OK.
    You can activate secure receiving mode without setting a password, but cannot protect your faxes.
  6. Re-enter the password to confirm it and press OK.
  7. Press Stop/Clear to return to ready mode.
When a fax is received in secure receiving mode, your machine stores it in memory and shows Secure Receive to let you know that there is a fax received.
Printing received faxes
  1. Access the Secure Receive menu by following steps 1 through 3 in "Activating secure receiving mode."
  2. Press the left/right arrow until Print appear and press OK.
  3. Enter the four-digit password and press OK.
    The machine prints all of the faxes stored in memory.
Deactivating secure receiving mode
  2. Press the left/right arrow until Off appear and press OK.
    The mode is deactivated and the machine prints all faxes stored in memory.
  4. Press Stop/Clear to return to ready mode."
Feb 10, 2015 | Samsung SF-650 Laser Fax/Copier
I cannot set my MFC 8460n to receive faxes - it says it is in DR mode
Press Menu, 2, 0, 2
Press Stop/Exit.
Mar 05, 2011 | Brother MFC-8460N All-In-One Printer
My brother mfc6490cw says dr mode what is this
DR stands for distigntive ring.
Before you are able to change the receive mode, you will need to turn off DR.
To turn off DR press MENU, then the down arrow until FAX and press OK. Then with down arrow choose MISC and press OK. Then with down arrow chose DISTINGTIVE and OK, then down arrow until OFF and press OK.
Jun 06, 2010 | Brother MFC 210C All-In-One InkJet Printer
Intellifax 2820
DR mode means that the distigntive ring feature has been activated so it will not let you change receive mode. You need to turn off DR first. Press menu/set then 2, 0, 2, then press the down arrow till you see distigntive off then press menu/set.
Now you should be able to change the receive mode to fax only!
May 29, 2010 | Brother IntelliFax-2820 Laser Fax
Can't set mode to receive fax, read through manuel says DR mode in use. fax does'nt pickup when a fax or call comes in stuck in manual.
Press Menu/Set.
3 Press Stop/Exit.
Apr 16, 2010 | Brother MFC 210C All-In-One InkJet Printer
Jun 24, 2009 | Brother MFC-465CN InkJet Printer
I'm not able to receive faxes
I figured it out by pressing the Receive Mode button and changing the selection from Manual to Fax.
Feb 18, 2009 | Brother FAX-575 Plain Paper Thermal
Fax history
Depending on your model, You need to press the MENU button, or check if there is a REPORTS button. For either case, scroll through the display until you come to the PRINT REPORTS mode. It may be worded differently on your machine, but what you are looking for is the FAX ACTIVITY report. You can also get printouts of TRANSMISSON OR RECEIVE ACTIVITY, and also CALLER ID, iIf you encounter a command called PROTOCAL DUMP, this also is a printout of fax activity.. Whether your activity report goes back to july 2007 is unknown. Normally an activity report shows a certain number of activities per printout, say the last 50 fax operations. It is not based on a certain timefrane.
Jan 09, 2008 | HP 920 Plain Paper Fax
Fax will not recieve
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
Nov 03, 2007 | Brother FAX-575 Plain Paper Thermal
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
