Question about Jura Capresso C1000 Espresso & Coffee Maker
Any substitute for Capresso cleaning tablets?
2 Suggested Answers
  • 10 Answers
SOURCE: Problem for Jura Capresso C1000 Espresso &
save a bundle, URNEX makes cafiza tablets, buy them by the 60 tabs or larger containers. Use them frequently and give some to friends. I've used them for years. find them online.
Posted on Apr 15, 2010
Z5 asks to add tablet after adding tablet....
Hi, after you have put the tablet in, press the rince button to continue the cleaning process. Dazza REPAIRER
Sep 24, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
I need to clean my capresso c1000. i can't find the instructions. i put a cleaning tablet into the ground coffee area, and ran the ground coffee button a few times. is that it?
No, first push the self clean button (hold until lights come on). Then pull the grounds unit and empty it, that will turn off one red light. Fill the water tank. Then drop the tablet. Then hit the ground coffee button. Cycle through and dump the grounds each time the grounds light illuminates.
Jul 09, 2011 | Jura Capresso C1000 Espresso & Coffee...
Impressa S9 keeps beeping "clean now". Have run cycle several times. Tried cleaning out the tamping disk area. turned machine on and off. Still getting the "clean now" message and beeping.
There could be several reasons for this problem but I can only think of the following:
1.) The internal sensor may have gone "bad". The sensors are sensitive and prone to failure. But before you give up, see #2 & 3 below.
2.) A few things to check:
- Make sure you are using the recommended white cleaning tablets*. If the tablets aren't used then there may still be oil build-up in the brewing chamber.
- When indicated during the cleaning cycle, be sure to remove the tray and bean container for at least 20 seconds and then replace, even if they are already empty.
*Cleaning tablets can be ordered from www.capresso.com.
3.) If you don't have cleaning tablets on-hand then you can try running a regular brewing cycle using white vinegar** instead of water. Follow with at least 2 cycles of clear water (to rinse) before brewing your first cup of java.
***This method is probably not recommended by your manufacturer. I have used it on my machines without incurring any problems but I can't guarantee that it's safe for your machine.
Additional resources:
The entire pdf instruction manual for your machine can be downloaded from the following website: http://www.capresso.com/pdf/s9_instructions.pdf
Good Luck!
Jun 24, 2010 | Jura Capresso Impressa S9 Coffee...
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
May 16, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
I do not have an instruction booklet, and need to clean my machine with a tablet - what do i do?
You can obtain the PDF booklet online from www.capresso.com
If you don't have access to the internet, just follow LED indicators. When you get a message to clean machine, you will see one of the indicators lights on. press the button and follow directions. You will be prompted to insert a tablet and press another button
Nov 11, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Capresso s8 weak coffee
You should probably run a cleaning cycle with a cleaning tablet (the one you drop into the ground coffee shoot, not a decalcifying tab).
This will clean out all the insides where coffee particles and oil can accumulate.
The machine will ask you to run a cleaning cycle after a certain number of cups brewed. But you can also manually start it.
(this is copied from the manual)
You can run a tablet cleaning cycle at anytime even if
the machine does not prompt you,
• READY. Push and hold the Rinse button until display shows
RINSE. The Dial illuminates.
• Turn the Dial until display shows CLEANING. Push the Dial.
Display shows EMPTY DRAWER.
(Follow the rest of instructions for regular cleaning cycle)
Jan 16, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Ordering cleaning tablets
I just called Bosch and they had them available. The product number is 310575
Oct 16, 2008 | Bosch Benvenuto B20 Espresso & Coffee...
Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
May 12, 2007 | Jura Capresso Impressa E75 Espresso &...
Jura Capresso C1000 Espresso & Coffee Maker Logo
143 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
