I have a Boston Acoustic Subwoofer CR400 and when I have it plugged in it will make a continuous buzzing sound. The subwoofer is about 9 years old. What can I do to fix the buzzing sound?
SOURCE: Buzzing Cerwin Vega LS-12 Subwoofer
If it's not interference or a ground problem it might be a bad amp. I have the same sub and not only did I have the buzzing, but also a noticable "whacking" sound instead of smooth bass. I found an online seller who at the time just happened to have obtained some surplus Cerwin Vega amps that fit perfectly. Paid $60 shipped. Problem solved.
Posted on Feb 23, 2008
HDTV GURU
  • 261 Answers
SOURCE: need help installing subwoofer
Just run "RCA" cable to sub and split off to both L&R with y adaptor and hookup to suboutput on receiver and plug into outlet and you should be a bangin then. GOOD LUCK. GURU JAY
Posted on Mar 22, 2008
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
  • 31 Answers
SOURCE: Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Posted on Jan 06, 2010
jhinsincity
  • 616 Answers
SOURCE: No sound from the subwoofer
Fuse is probably blown
Posted on Apr 13, 2010
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Loud humming sound
Make sure that the input connection ground is good. If that does not cure the loud hum then you have a power supply issue.
Oct 27, 2015 | Boston Acoustics Boston Acoustic Micro...
Kenwood KM-X1
I suggest build new non-powered woofers with cabinets.
If you really get serious with your sound you'll need a workshop
for customizing it all. A converted garage is nice.
See mine in photo for an example:
Oct 13, 2017 | Audio Players & Recorders
Acoustic reaserch subwoofer dont have any sound
If this is a powered sub then it's most likely the internal amp inside it that has failed. It's more than likely the part that works the hardest on the board. IE the main amp semicoductor.
Dec 19, 2012 | Boston Acoustics Audio Players & Recorders
BA745 Boston subwoofer does not work
Did you check to see if the subwoofer is receiving power?
Jul 13, 2017 | Boston Acoustics BA745 Computer Speakers
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Hello
Did you find the value of ZD3.
I need it too.
I have the same problem, and I take out the ZD3 and the subwoofer works. But I'm not sure that is correct. I think it may be the circuit stand by.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
Subwoofer shut down
The amplifier probably has a built in protection circuit to keep from over driving the subwoofers. This will prevent the dealer from replacing woofers........most likely it's designed to be overly safe.
There's likely not much you can do about it, if there's not enough bass you may have to seek out a larger amplifier.
Oct 09, 2008 | Boston Acoustics Competitor 1200 Car...
Need help installing subwoofer
Feb 19, 2008 | Audio Players & Recorders
388 people viewed this question
 Grubhead
Grubhead
