Question about Canon PIXMA MP150 All-In-One InkJet Printer
Some lines of type in printouts have white lines.
    Scholar:
  • 111 Answers
White streaks on an ink jet printer mean a clogged print head. Click on the printer manufacturer's software and do a head cleaning. If that doesn't work, you'll have to buy a new cartridge.
Posted on Oct 04, 2009
IR 3035 black copy
<Cause>
On some types of paper (especially those with a high calcium carbonate content), toner offset to the fixing film can
start to cake, moving from the fixing film or the pressure roller to the face or back of paper.
<Field Remedy>
Use the following service mode item to change the timing at which the fixing pressure roller is cleaned:
COPIER>OPTION>BODY>FIX-CLN
0: disable cleaning (default)
1: execute cleaning during last rotation every 500 printouts
2: execute cleaning during last rotation every 200 printouts
3: execute cleaning during last rotation every 100 printouts
Feb 14, 2017 | Canon imageRUNNER 3035 Black and White...
Every 10th line of print is fuzzy. We have tried all the usual fixes, head clean, nozzle check. What next
What should I do if my printout is blurry or smeared? - Epson ...
https://www.epson.com/cgi.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If your printouts areblurry or smeared, try these solutions: ... If you print on both sides of a sheet of paper, smudges may appear on the reverse side of heavily saturated or dark ...Missing: every ‎10th
What should I do if my printout has lines running ... - Epson
https://www.epson.com/cgi-bin/Store/.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If you notice white or dark lines in your prints (also called banding), try these solutions before ...Missing: 10th ‎fuzzy
FAQs for this Product - Epson WorkForce WF-2530, Top ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
EpsonThis link provides access to Top FAQs for the Epson WorkForce WF-2530. ... [ Answer ]; I see the message Printer is Offline when I try to print with a ... [ Answer ]; What should I do if my printout has lines running through it? .... When printing in Windows, how can I prevent an extra page from being ejected after every print job?
Jan 19, 2016 | Epson WorkForce WF-2530
Printing vertical green lines on photos
The troubleshooting section for banding below was taken from the user manual found at this web link:
https://files.support.epson.com/pdf/wf3520/wf3520ug.pdf
White or Dark Lines in Printout
If you notice white or dark lines in your prints (also called banding), try these solutions before you reprint:
• Run a nozzle check to see if any of the print head nozzles are clogged. Then clean the print head, if necessary.
• Make sure the paper type setting matches the type of paper you loaded.
• Make sure you loaded the printable side of the paper correctly for your product.
• Turn off any high speed settings in your product software.
• Align the print head.
• You may need to replace the ink cartridges.
Hope this helps...
Dec 21, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
Vertical white lines appear in my printouts.
Hi
white line or paper prints are enduring problems in the printer heads. software for cleaning the printer heads and see the results, if necessary, you must convert to the new printer heads
regards
Mar 23, 2011 | Canon iP100 Portable Printer
White line along printout
Have you tried cleaning the printer cartridge heads? If this fails or you have already tried, please see my tip on manually cleaning them:
http://www.fixya.com/support/r4304395-fix_or_repair_or_clean_or_unclog_inkjet
Mar 12, 2010 | Canon Pixma iP6000D InkJet Photo Printer
White and black lines appear on copies
do an internal printout and see if any lines occur... if none... then clean the glass table and the **** glass and anything else that touches them... look for white out and dark spots...
if yes... then check your fuser... see if there are any lines on it... if there then fuser bad...
then check your drum to see if there are any lines on it... if there then bad drum...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 16, 2009 | Sharp AR-M205 Copier
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Verticle color lines on scanner bed and printout in photo mode
Hardware failure, nothing much can be done, just replace the scanner.
Aug 27, 2009 | Epson Expression 1640XL Graphic Arts...
White bands across printouts
Either one of the print heads are bad or a cartridge. This is what causes that problem. I know it is a hassle but I would take it back. If try and fix it you could void the warranty.
Mar 16, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
