Question about Plantronics (45647-04) for S10, T10, T20 Consumer Headset
Headset not working
I dropped my phone (Plantronic T10) and the headset plug does not fit into the phone tight. I can hear the person I call but they can't hear me.
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
The fine wires in the cord casing do break easily. If your RJ9 connection is loose, then the brass contacts are not making good contact inside the T10 base. Not many options, unless you can get the RJ9 clip repaired, but to get a new system.
Good luck from Headsets Direct!
Posted on Dec 20, 2011
I have plantronics t10, i have been able to use it in the past, but tried to plug it in today and the base red light (on/off) lights up red, but no dial tone. none of the buttons work.
It might be that you have a cord plugged into the headset jack. Try looking at that, if that is not it, it may be the cords are not plugged into the correct spot. I am sending you the Plantronics user guide for the T10 headset.
Jul 18, 2011 | Plantronics T10 Corded Phone (0031-t10)
My new blackberry pearl no reconnize my plantronic 330
Test the headset on another phone, if it doesn't work on the other phone then your headset is defective. Connecting the headset to the blackberry is fairly simple. Just verify that the Blackberry's bluetooth connection is active and make sure the headset's connection is active as well. Select the plantronics headset within the Blackberry's bluetooth menu, it should be listed in the menu if the headset is working.
Mar 05, 2011 | Plantronics Explorer 330 Headset
High pitched sound when attempting to use the headseat rather than the handset. I have tried all of the settings on the side of the desk moduel.
It sounds like it may be plugged into the wrong jack on the phone base. The cord from the S10 HAS TO BE plugged into the jack where the curly cord from your phone was plugged in. You can't use the headset jack, this will cause the high pitch sound you are hearing.
Dec 13, 2010 | Plantronics (45647-04) for S10, T10, T20...
What causes the Plantronic H251 to have static and fades during radio transmissions?
There are too many variables with this question. The S10,T10,T20 are designed to have a specific headset used with them. If you have purchased a cord with a quick disconnect on one end and a phone type plug on the other and then plugged it into the base amplifier using a H251 headset that may be why there is static. I would say that you need to have the original headset or correct replacement for the base.
Oct 26, 2010 | Plantronics (45647-04) for S10, T10, T20...
I have a Plantronic headset. I have moved to another location (and phone jack) in my office. The Plantronic headset plugged into the Panasonic KX-T7633 does not get a dial tone. When I go back to my...
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Oct 29, 2009 | Panasonic KX-T7633 Corded Phone
Plantronic 340 headset
try 9999 or 1234 or the last 4 of your phone number. let me know if it works
Mar 19, 2009 | Plantronics Explorer 340 Wireless Headset
PLANTRONICS Headphone won't work with IP 501 sip, polycome phone
Dont plugged into the headset jack. Like Nortel, connect headset line with phone base unit in receiver jack and plugged your phone receiver wire into headset or plantronic base unit. This will work. I am sorry, my english is not too good but hope you understand it now. But the pully is not working properly with IP501..I mean it is not good to pickup IP501 receiver and put it back right place.
Dec 17, 2008 | Polycom SOUNDPOINT IP 501 SIP
Plantronic 510s
The Voyager 510 is not a good fit for that phone. I would prefer the cs55 or awh55.
The headset will work with the phone, but will not alert you when there is a call.
Jul 03, 2008 | Avaya 5400 Series 5410 Phone
Plantronics headset S10
First, try a headset that you know works.
May 10, 2008 | Plantronics (45647-04) for S10, T10, T20...
Headset
it might be that the speaker/buzzer of your phone is already busted or perhaps just a lose connection. Let a phone technician inspect it. It can also be that the phone is locked to its headset state, this means that the phone always reads that the headset is connected, in this case just restart your phone. Be sure to check also if the profile is not set to headset. These are the possible causes i assume but i think its more on the hardware problem.
Please Rate Thanks
Jan 08, 2008 | Nokia 3200
Plantronics (45647-04) for S10, T10, T20 Consumer Headset Logo
105 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
