Question about Minolta Di3510f Bizhub Copier
How and where is the cartridge for this copier?
  • Adorjani Laszlo May 11, 2010
    Describe your problem,see the owners manual.
  • Minolta Master
  • 1,294 Answers
What cartridge?This machine use Image Unite and toner bottle.
Posted on Sep 26, 2009
I cannot get the drum cartridge out of the XC356 copier by Xerox. I have lifted the green tab, however it is still locked or hard to come out and I am afraid I will break same. Do I need to do something...
You can always find a soution to your Xerox problem at www.xerox.com/support Here is a link to this solution:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=22,E=0000000002703238142,K=7389,Sxi=4,Solution=obj(18692)
  1. Turn the copier off.
  2. Remove the Toner Cartridge:NOTE: If you are not sure how to remove the Toner Cartridge, refer to Related Links at the bottom of this page.
  3. Remove the Input Tray on the right side of the copier, if applicable.
  4. Slide the Platen to the right by pushing in on the grey square Release Button on the back of the copier, then sliding the Platen.
  5. Fold up the Exit Tray on the left side of the copier, if applicable.
  6. Stand the copier upright on its left side.
  7. Remove the Bottom Access Door (see Related Links).
  8. CAUTION: Be careful not to touch the red surface of the Drum.
  9. Locate the green Drum Cartridge Release Lever at the bottom of the Drum Cartridge.
  10. Lift up on the Drum Cartridge Release Lever.
  11. Pull up on the bottom of the Drum Cartridge. The Drum Cartridge will pivot upwards.
  12. Pull back on the Drum Cartridge to remove it from the copier.
Jan 26, 2011 | Xerox XC356 Copier
Replaced yellow cartridge, but the copier keeps telling me to replace that cartridge and will not print.
cange the cartridge again and use original cartridges... Maybe the Cartridge does not work correctly.
Dec 29, 2010 | HP Color Copier 190 Copier
MFX-2830 Black and White Copier: How do you replace a staple cartridge on a Muratec...
Open front door of the Finisher Unit. Over to the left beside the 2 green knobs you will see the Staple Cartridge. Pull slightly down and out and the cartridge will come out. A new cartridge has to be installed...they cannot be re-filled.
May 17, 2010 | Muratec MFX-2830 Black and White Copier
Does my copier have a drum cartridge and toner cartridge or is it all the same
It has separate drum and toner cartridges.Toner cartridge is located at the front (small dor on the right side).Drum cartridge is located at the bottom side of the mashine.
May 08, 2010 | Xerox XC356 Copier
Install cartridge message displaying on my machine
When your cartridge is not adjust properly.
install your old cartridge.If this massage again may be your machine .Right side drum charge lock not adjust.Or machine ready so problem on cartridge.
Cartridge part no T series toner cartridge SG 35 is appropriate model.
Jan 26, 2010 | Canon imageCLASS D320 Digital Copier
Error code F2-04. Have replaced cartridge but to no avail for the Sharp Model # AR 168S Copier.
Try this solution I found on an other site.
In a Sharp MX-M450N copier this is due to improper cartridge.
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off
2. Remove the incorrect toner cartridge
2. Unplug the power cable from the wall outlet.
4. Plug the Printer back on
5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
6. Insert the old or new correct toner cartridge into the copier.
Dec 28, 2009 | Office Equipment & Supplies
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
The ink cartridge in my Canon - PCII is stuck.
put off your copier. kindly look at the side where your paper exit , u see an opener, this will open the copier. then draw the cartridge
Dec 05, 2008 | Canon PC-940 Black and White Copier
Problem with changing the Toner Copier Cartridge
F2 has to do with a toner sensor not working. It could be the replacement cartridge is missing something. Make sure you use a genuine Sharp toner cartridge and that should take care of the problem.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Solution for copier
Your copier does not like your toner cartridge. Make absolutely sure you have the proper cartridge AR-202MT. Or, the countdown chip in your cartridge has reached zero or is malfunctioning. In any case, try a new toner cartridge.
Apr 05, 2008 | Sharp AR-M205 Copier
62 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
