Somebody has bee playing with your Laptop and making you a ugly joke !!
You have to reset your Bios then !, you do it in this way :
Resetting the BIOS Password using HardwareIf you cannot access the machine after if has been powered up, it is
still possible to get past the BIOS password. The BIOS password is
stored in CMOS memory that is maintained while the PC is powered off by
a small battery, which is attached to the motherboard. If you remove
this battery, all CMOS information (including the BIOS password) will
be lost. You will need to re-enter the correct CMOS setup information
to use the machine. The machines owner or user will most likely be
alarmed when it is discovered that the BIOS password has been deleted. On some motherboards, the battery is soldered to the motherboard,
making it difficult to remove. If this is the case, you have another
alternative. Somewhere on the motherboard you should find a jumper that
will clear the BIOS password. If you have the motherboard
documentation, you will know where that jumper is. If not, the jumper
may be labeled on the motherboard. If you are not fortunate enough for
either of these to be the case, you may be able to guess which jumper
is the correct jumper. This jumper is usually standing alone near the
battery. If you cannot locate this jumper, you might short both of the
points where the battery connects to the motherboard. If all else fails, you may have to clear the BIOS password by
resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your
motherboard. Many RTC's require an external battery. If your RTC is one of this
type, you can clear the BIOS password just by unsocketing the RTC and
reseating it.
Remember that laptops can be trickier, especially if it's a newer
model. If it has a security chip on the motherboard forget about it.
You either have to physically remove the chip or contact the mfg for
the "master" password. If you can boot up off of a cd or floppy try any
of these methods:
Create a Win98SE bootable media "or anything that lets you boot into MS-DOS" and boot off of it.
When the A:\> prompt appears type debug and press enter.
You will then only see a "-".
Type o 70 2E "include the spaces" and press Enter.
Type o 71 ff "include the spaces" and press Enter.
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
Other passwords you may try (for AMI/AWARD or other BIOSes) -
LKWPETER, lkwpeter, BIOSTAR, biostar, BIOSSTAR, biosstar, ALFAROME,
Syxz, Wodj gvs
. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most
effective.: BIOS/CMOS Password Recovery Tool is a program that works
instantly to remove any lost or forgotten BIOS/CMOS password. Simply
boot your PC to DOS and execute the program, and get access to
forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Trying to link cell phone to desktop in order to download pics & music from it, but Windows...
(More)
Trying to link cell phone to desktop in order to download pics & music from it, but Windows has no drivers for the Qualcomm A200 phone.
I have a your PC Backup and backed up my files before I got a new PC with Windows 7. I cannot...
(More)
I have a your PC Backup and backed up my files before I got a new PC with Windows 7. I cannot restore my files to my new PC with Windows 7. What can I do?
