Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Trying to push riding lawnmower up ramps to take it to repair shop and the back wheels are locked. We can't get them to move even if in neutral. Help! Can't get it fixed if we can't get it to the shop. Too heavy for two of us to pick up. thanks!
    Top Expert:
  • Craftsman Master
  • 12,650 Answers
Look under seat for a pull up button this overrides the rear and lets wheels roll free if not under seat on rear axle lever to release rear wheels
Posted on Sep 27, 2009
  • 389 Answers
If loosening the brake doesn't help, you can lift one rear wheel and the other will roll freely
Posted on Sep 25, 2009
  • 437 Answers
The brakes have locked up. Look under the right rear side of the mower, between the wheel and transmission. You should see a disc, similar to disc brake on your car but a smaller version, There is a nut you can turn to take the pressure off the brake pad. Should take a 1/2" wrench to do this.
Loosen it enough to get the mower to move back and forth then you should be able to load it up on your truck.
My 2004 Santa Fe will not start steering wheel will not lock I wonder if that's the problem just started yesterday.
The wheel (all theft and safety) locks are connected to other components. They are on shifter, brake, and steering wheel. Try putting vehicle in neutral and with foot on brake see if it will start like that. It may just be a little off for wheel, brake, and shifter to mesh and lock up. They all have a say in how it goes. If vehicle is on hill of any kind it can keep locks from going, if wheel is turned to odd spot, or lock from shifter is off, they can all keep system from locking up. Would guess that it is not starting because one of the neutral safety switches is not engaged and wheel lock is kind of a side affect of this also. If you can take key out of ignition but wheel is not locked there is clearly an issue with the lock up system. But the wheel lock points are not at every inch of wheel turn. Sometimes you turn vehicle off with wheel at a point a little off from one of the holes and you just turn wheel a bit and lock will engage. But try starting in neutral - try moving shifter all the way back and then into park (with brake pushed) and see if they will get back in sync. You may have to push / roll vehicle a little to get weight off shifter and wheel, but if shifter moves from park with no brake, or key comes out with no wheel lock (or with shifter not in park) something in the 3 way lock system has come out of sync.
Feb 16, 2015 | 2004 Hyundai Santa Fe
Why are the wheels locked on Jeep ? Won't even roll in Neutral!
so you did get the key to move enough and brakes on to move the shifter to neutral.
are you an the arctic circle, (i have a buddy there,) pop 100.
hand brake off,
park dis-engaged, neutral
if it dont move the brakes are locked
or one axle bearing is seized.
so jack up each wheel 1 by 1, and see if it turns
on flat ground, and other wheels chocked so car can not roll.
i bet all 4 can spin,
and you just can push this heavy pig. i can barely do my wrangler.
you tried to hand push a car?
lets work no starts
does it crank over in park/?
does the engine crank fast , while in the start position?
my guess is the park lock out is fooling you.
most cars the park lock up is complex now.
its really in park not neutral.
and the reason , blown fuse. my guess.
tell all that works key, on in details
head lights, not just my lights work say HEAD
they draw like 10 amps of current, about 100x more that other lights.
even better
does engines start with jumper cables, jumped from a running car.
donor car.
can AAA start car?
if yes, post that first. all else is effect not cause.
Aug 28, 2014 | 2006 Jeep Liberty Sport
Brought riding mower into the garage thru a side door,after that back wheels locked up would not start after that ?
try bringing it in the front door but I don't think that will fix the problem. if the wheels are locked up there is a safety switch that will not let it start if the trans is in gear
May 26, 2014 | Garden
Craftsman 24 hp 46 can't be pushed manualy while in neutal
there is a release rod on the rear of the machine you pull out to place in push mode there is a spot to lock it into place
Aug 04, 2012 | Garden
Can't push troy bilt lawn tractor when it is in neutral
It sounds like the tractor is hydro, if so you need to find the release lever to allow it to move in neutral.
Most hydros have the lever under the seat or at the back of the tractor just behind the back wheels.
if and when you find it, it will need to be slid across and locked in to the operset position or pulled out, depending on what type it is.
Hope this helps
Regards
Micky
Jun 14, 2012 | Troy Bilt 175HP Manual 42" Riding Mower
Wheels are locked cannot move in neutral
If, t's a Craftsman You might can go to rear of your Mower and Release the Freewheel Control Level.
Nov 11, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rear Wheels won't move on riding mower when off and in neutral
Sounds like the pins/dowels in your brake caliper have gotten dirty and/or rusty and are not releasing all the way. When I had my shop, we found a lot of these and I or my mechanics pulled and cleaned them then took a drill 1/64th larger than the pin/dowel and ran it through the holes in the caliper, NO MORE PROBLEMS!
Sep 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My poulan riding lawnmower will not roll. The
Hi..my name is Keith..and it sounds like the neutral rod on the back of the mower needs to come out further to fully disengage the transmission so you can roll it..it should have an adjusting nut on the rod..and i would turn the nut in a couple of turns until the lawn mower will roll..i hope this will help..if not please write me back
Jul 12, 2009 | Garden
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
814 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
