Question about Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome...
Leaking under sink and st base on sink
When faucet is on at med-full power, it leaks at base and water running down hoses under sink. It seems to be the flex hose that allows you to remove handle for washing.
I tried to remove the flex hose, but I can't get it to feed through either side.
  • 54 Answers
Remove spray head then faucet tighten connection on the spray hose
Posted on Sep 26, 2009
Giagni Pompa Stainless Steel 1-Handle Pull-Down Kitchen Faucet
Without seeing the leak and checking further I can't say yes or no.
Nov 11, 2016 | Plumbing
Water leak at base of faucet on granite and onto hose under sink. its coming from the faucet not the hose.
You don't mention the brand but most faucet Mfgrs have rebuild kits.
May 26, 2015 | Home
Hansgrohe axor repair
follow this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals.
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 26, 2013 | Home
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Jameco single handle kitchen faucet with spray is hard to turn
The water coming out the shower jets is not powerful, help?
If a faucet leaks, replace seals and gaskets .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
Solaris Model #06544860 leaking under the sink. How do I remove and how do I figure out exactly what is leaking?
The first thing I would do is to locate source of the leak. Look carefully at faucet when it is on and see if you have any water leaking from areator and running back down the underside of spout and leaking around base of faucet, also see if you have any leaks around handle. If the leak is from the areator you can just replace it and not have to remove the faucet. when you check under sink on faucet supply lines make sure they aren't leaking at that point. I would use paper towels or rags to wipe everything dry under faucet and let it set for 1/2 hour then check again. If it.s still dry run some water and use both hot and cold water seperatly,checking underside in between. If you determine that leak is coming from top side and leaking thru. Shut off water supply valves if available if not shut off supply to house, make sure water is off before proceeding. Disconnect supply lines from faucet,Remove retaing nuts on either side of base,and remove washers. Remove faucet and check for any obvious faults. If you think it was leaking around base get a small tub of plumbers putty. Most hardware stores stock it. Remove a golf ball sized portion or larger and knead in your hands until it is warm and pliable. Press into place in faucet base. Continue doing this until it's full. Reinstall plastic or rubber base gasket and put faucet back in place Put washers and retaing nuts back on a tighten till snug. Center faucet where you want it and tighten securely. Scrape off excess putty with knife point and wipe with paper towels till clean. Hook up supply lines and turn water back on. Check for leaks and good luck. Thank you
Nov 27, 2010 | Hansgrohe 06649860 Solaris Single Hole...
I have a kitchen sink faucet that is leaking water from the back part of the faucet. There is a hole there and the faucet leaks water, when the water is on. Why is it doing this?
If it is a rusted hole get new faucet, but on many faucets that is where the Sprayer connects. Check for loose Sprayer hose at faucet under the sink.
Sep 14, 2009 | Plumbing
Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome... Logo
1,112 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
