Question about Samsung L200 Digital Camera
No display the lens will not go back in and when i turn the camera on there is no display and you can not turn it off again
Lens is in projected conditon, turn power off and on again shows in the display
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Mar 06, 2011 | Sony Cyber-shot DSC-W300 Digital Camera
Turn the power off and on again
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
On the screen shows turn off and then turn on again and again-it does not turns on any way
Jan 17, 2011 | Sony Cyber-Shot DSC-W7 Digital Camera
DS-W370 lens the lens of the camera are out and i get a message to turn off the camera and try again but never worked
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Main Settings Menu of the Camera to OK. (Menu-->Settings-->Main Settings-->Initialize-->OK.)
Jan 10, 2011 | Sony Cybershot DSCW370 Digital Camera
Camera turns on, lens cyles (in and out) 3 times, then camera displays a message "Turn the power off and on again" superimposed on the display. Image is not in focus and camera will not take picture, just...
This is lens mechanism problem and lens assembly will be replaced to fix the issue.
Lens tries to correct its mechanical error three times then gives up and you see turn power off and on again display in lcd. If camera is under warranty, please call Sony to get it fixed or take camera to local camera repair shop if its out of warranty.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Turn the power off and on again message
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Err message appears on the display of my D80.
This may be due to the aperture ring in your lens. Try the following:
1. Turn off your camera
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Nov 08, 2009 | Nikon D80 Digital Camera with 18-135mm...
Problem
I had the same problem and fixed it.
The problem is related to the lens not working properly and jammed up.
When powering on the camera, the focus goes in and out and the lens spin and then the message is displayed to turn camera off.When I turn the camera off, I noticed the lens did not fully hiberate into the camera like it did before the error message.
So to fix the problem I did the following:
Turn the camera on, when the lens extended out, I slightly rotated the outer most lens clockwise and counterclockwise to free the lens from the jammed position.
The error no longer appeared and the camera stayed-on.When I shut the power-off the lens completely hibernated again like normal.
Hope this helps.
Pete
Dec 25, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
"00" Apparture
If an aperture of "00" is displayed on the camera's LCD panel, perform the following steps in order. Check after each step to see if the problem remains, and proceed to the next step if it does. (In some cases, you may see "Err 01" displayed on the LCD panel.) 1. Check if the lens is correctly mounted on the camera. If no lens is attached to the camera, "00" will be displayed for the aperture value. 2. Clean the lens contacts. Turn the camera's power switch to OFF, and then detach the lens from the camera to clean the contacts. Use a blower to blow away dust on the lens. Do not touch both the camera's or lens' electrical contacts with your fingers while cleaning the lens. Turn the power switch to ON again and check the aperture value displayed on the LCD panel. Refer to the Instruction Manual provided with your camera for instructions for detaching or mounting the lens. Also, prevent any foreign materials or dust from getting into the camera through the lens mount, and be sure not to damage the contacts. 3. Remove the battery pack. Turn the camera's power switch to OFF and remove the battery pack. Then reinsert the battery pack, and then turn the power switch to ON again.
Aug 29, 2005 | Canon EOS-1D Mark II Digital Camera
Samsung L200 Digital Camera Logo
43 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
