Question about Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard
Disabling the onboard graphics for this motherboard
I'm not exactly sure how to disable the onboard graphics for this specific motherboard so my Geforce 5500 graphics card can be used instead.Step by step info on how to do this would be greatly appretiated.
    Champion:
  • 238 Answers
Hi, go to system bios, i think in the second options check out for primary display , you will have options for add on, or onboard, change it to add on, or there is also an option to disable the primary display somewhere there, browse the bios around , you will find either of it. let me know
Posted on Dec 17, 2007
Graphics error beep when booting once a graphics card has been inserted. no boot, black screen
Trite as it may seem, I see no mention of installing drivers for the graphics card.
Just disabling OnBoard/Integrated graphics.
Post back in a Comment.
Regards,
joecoolvette
Apr 01, 2013 | Computers & Internet
How do i disable onboard video on a intel d865glc motherboard?
A couple things to try:
  1. Most important, check with Intel's support site to see if you have the latest version of the BIOS.
  2. Boot to the BIOS: Choose "Configuration", then "Video", choose "Enable if Primary" or if you're feeling brave choose to Disable it entirely. WARNING: DON'T do this until your other card is working properly! You've been warned!
  3. While still in BIOS: Choose "Configuration", then "Video", choose "AGP" if available, or "Auto" if AGP is not an option.
Information from Intel support website.
Oct 21, 2012 | Gigabyte GV-N76G256D-RH GeForce 7600GS,...
Disable onboard video on e machine w3653
Start device manager typing 'devmgmt.msc' in run box. Frome there you can select Graphics devices and disable the specific device.
May 31, 2012 | Computers & Internet
Video not working on 755Twins-hdtv motherboard.
The option to disable the onboard graphics is in the BIOS.
You need a PCI-express card. You should not be trying to fit any graphics cards into the PCI slot.
The VGA/HDTV conection should have been supplied on a seperate card.
Your support page is here http://www.asrock.com/mb/overview.asp?model=775twins-hdtv
Aug 01, 2010 | Asrock Computers & Internet
Computer - Intelchips 82945G - Error Code 43
When your computer loads, after you power it on, it gives you an option to go into the CMOS. You can disable integrated periferals there. If you don't know how, check your system documentation
May 10, 2009 | MSI Computers & Internet
Comp will not recognize my agp radeon HD2400 pro graphics card
Try the following : Go into the setup routine using the onboard video. Go to the  Intergrated Peripherals.
Find the onboard video and change it to disable. Save changes.
Change monitor to the AGP card.
  I hope this helps.
Here is a web site for your Award Bios setup:
http://www.buildeasypc.com/sw/bios_setup.htm
Inegrated Peripherals
This menu allows you to change the various I/O devices such as IDE controllers, serial ports, parallel port, keyboard etc. You can make changes as necessary. See figure 5.
Dec 19, 2008 | Biostar P4M80-M4 Motherboard
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
System doesn't see AGP card
Hello flaxx
I believe you'll need to find a way to disable your integrated (onboard) video in the BIOS. I know there isn't a direct way to do it but, please, see the next link. The user there found a way.
HERE is the way another user accomplished this task. (disabling onboard video). It concerns a different Asus motherboard but, I checked your motherboard manual, those same features are available.
HERE is the AsusTek forum for your motherboard. You can search and post here. There will be other users of that same board there that I'm sure will be able to help you.
HERE is your motherboard manual. However, I didn't see anything that particularly addressed disabling the onboard video.
Please, post back here w/ your results, questions, and any comments, etc.
Thank you
BJ @:)
Apr 12, 2008 | ASUS P4GE-MX Motherboard
Gigabyte 7VM400M-Rev.1 Onboard Video
format ur computer once again.. n install the driver..
Feb 14, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
No video output
try this -remove the card then restart the pc (if this is xp) start/right click my computer/properties/device manger-look for "display adapters" find the onboard type you have and uninstall it power off then install the new card you might have to look in device manager for something referred to as graphics controller
Oct 05, 2007 | ASUS P5VD2-MX SE Motherboard
Open Questions:
Steps To Fix Toshiba Laptop virus and Freezes Issue Call toll free Number :+1888784-9316 Are you facing sudden pop-ups on your computer or witnessing slow loading of files and programs? If you are getting issues like slow internet and processing, unexpected computer behavior then contact Toshiba support for making your computer free from all such dangerous online threats. Toshiba support provides safe and secure removal of all virus and other infections along with protecting the system from any such instances further. Toshiba support providing technicians make sure that your pc is secure and also that all your important files and documents are safe from any type of harm. If your system is infected with viruses, Trojans or malware then it might show signs like slow computer processing and internet speed, unexpected computer behavior, sudden freezing and crashing down of the system, frequent arrival of error messages, many advertisement pop-ups, non-intended outgoing emails and messages to contacts, files disappearing, problems in hardware and accessory devices, screen freezing and image blurring issue etc. Toshiba support helps in scanning all the variants of virus inhibiting the system by using proper scanning process and removal processes after that. Many a times, user while scanning viruses on his system might not be able to remove all even after many attempts. This happens because system gets infected to new variant of virus due to vulnerabilities of programs used in that system or because of inefficient scanning methods. The anti-virus program used for scanning the presence of that virus might not have got that virus's signature. So, for proper and efficient scanning of all viruses and removal afterwards, it is necessary to take help from experts like Toshiba support technicians. These technicians utilize the efficiency of advanced techniques and much better tools to clean the system and make it infection proof in order to yield greater productivity. Specialists of Toshiba support collect samples of all the variants of new and recent viruses and update the user's software database with their signatures. In case your system is also suffering from the infection of any such viruses which is new and is creating trouble getting detected, then contact Toshiba support us for help on their toll-free Toshiba customer helpline number +1888784-9316 anytime for expert supervision and advice.
Aug 14, 2018 | Toshiba Computers & Internet
See all Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Questions
Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Logo
249 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
