Question about Cycling
How do you remove the reae wheel from a five speed schwinn suburban bicycle
    Sergeant:
  • 206 Answers
Should just loosen the nuts on each side of the axle. Assuming bicycle is upside down, you then have to lift the chain away from the sprocket as you slide it out of the slots of the frame that the axle fits in.
May have to loosen, adjust or remove the brake pads in order to slide the outer rim/tire through the brake caliper.
Take a picture first, so you can see how to deal with the rear derailer (sp?) when putting the wheel back on.
Posted on Sep 25, 2009
How to change rear tire schwinn suburban womens bike
Remove wheel, take it to the nearest bike shop for correct replacement and tire sizing. Schwinn tires are different than other tires. They use fractions rather than the decimal system everybody else uses. So a Schwinn tire won't fit on a decimal rim and a decimal tire won't fit on a Schwinn rim
Jun 01, 2014 | Schwinn Cycling
Removal of rear wheel gear on a 1972 suburban 10 speed
You can replace the spokes,without removing gears,by deflating,and removing tire. Each spoke will(should be held in by a machine screw. Detach from the rim,and slide out through holes in gear assembly. You would have to replace the spokes 1(or 2)@ a time;which admittedly,is a tedious process,but this should work. Peace. God bless.
Dec 16, 2013 | Schwinn Cycling
Where can I find an owner's manaul and parts list for a 1973 schwinn suburban
http://www.ebay.com/itm/1972-Schwinn-Owners-Manual-Continental-Suburban-Collegiate-Varsity-Sport-/160832409973
The moving parts on that vintage Schwinn are essentially the same for all of the listed bikes. I expect just about all are currently replaceable with new parts on an item by item basis if that is your need.
Aug 12, 2012 | Schwinn Cycling
Chain keeps slipping of the chainring
put chain on and tighten by pulling wheel back then tighten wheel nuts
Aug 01, 2012 | Schwinn Suburban Sport 26 Women's Comfort...
Removal of rear wheel with internal geared 3-speed and coaster brake hub
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Feb 24, 2012 | Cycling
Chain slips like it was trying to come off
If this is a seven speed Schwinn bicycle, you may be able to adjust the rear wheel (loosen the mounting nuts and slide the wheel rearward) or you may have a "stretched" chain and will need to remove a link (not an easy task without a chain breaker), hope this answers your question.
Dec 14, 2011 | Garden
My bike's suddenly not moving my bike's suddenly not moving backward..... its a Schwinn Suburban Sport 26" for women... bought it an hour ..
It's not supposed to move backward. Walk it forward and rotate the pedal FORWARD to get the chain and all aligned onto a gear. Then evaluate what is wrong.
Aug 14, 2011 | Schwinn Suburban Sport 26 Women's Comfort...
My 1970's schwinn suburban has 5 broken spokes on the real wheel. where do i find rear whell replacement ?
You can have the spokes replaced and the wheel trued and tensioned much cheaper. Bike Shop either way.
Jul 25, 2011 | Cycling
Old schwinn 10 speed rear wheel removal how
Release rear brake, either will have a lever on brake assembly or remove a brake shoe, shift to the smallest gear in rear, then loosen with a #15 metric box wrench, then push the wheel out. All bikes are metric, not just Schwinn. Then reverse to reinstall.
Sep 09, 2010 | Cycling
How do you use the 21 speeds on the Schwinn ladies coaster bike?
there are 7 cogs on the rear wheel hub; three on the crank hub:
7x3=21 gear change possibilities
large gears move the wheel faster and farther around but, with more effort
small gears move the wheel less distance but, with less effort
i.e. 10 teeth divided by 30 teeth= 3:1 per 360 degree rotation of the bicycle wheel
Sep 07, 2009 | Schwinn Cycling
Cycling Logo
101 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
