Question about Garden
Have Homelite 33cc gas 14'' chain saw won't start. Getting fuel, but no spark. Was told coil is bad but chain saw is brand new. How do I test the coil?
    President:
  • 2,220 Answers
Ignition Coil Test
http://www.youtube.com/watch?v=L7WNBDRG4C4&feature=PlayList&p=3789DC1EE87C8098&playnext=1&playnext_from=PL&index=21
You may need to use a jumper wire between the threaded part of the plug and the cooling fins.
If the saw is new return it for a replacement. An authorized repair facility should at the very least repair it at no cost to you.
http://www.homelite.com/
Under "Contact Us" select "Service Centers"
Posted on Sep 25, 2009
    Sergeant:
    Champion:
  • 205 Answers
Hello sir please check the ignition cable connected to the sparking plug as you start the machine current should pass through the ignition cable and makes the machin to run.
Husky 254.wont start.fuel is filling up the carb.running out the exhaust,has spark,new fuel filter,it wont fire not even a splutter
i dont know ,usually when cylinder fills up with gas ,the float seat and needle needs to be changed. but this is a 2 cycle chain saw and not a 4 cycle lawnmower. and it is 2 cycle which means that the air/ fuel mixture goes into the crankcase first, before getting to the cylinder. So you are saying to me that your crankcase is full of 2cycle fuel, youe cylinder is full of 2 cycle fuel and the exhaust is full of 2cycle fuel.
TIME FOR a new carburator
or at the very least,a carb rebuild kit
If you want to do the job just once and be sure it will be fixed,
buy the new carburatior, but a new carb is at least $46.00 plus tax and 7.00 to 12.95 shipping. and that price is for a 33cc homelite ranger,14 inch saw, which I might just sell for parts because it is a solid body,not anti vibration handle.
so ,is your husky worth spending slightly under $100.00 on
if not ,try rebuilding the carb, may only cost 20.00 to 30 for parts but might not work & be a complete waste of $
Im not fimiliar with husky prices, I know they are big cc, heavy wieght and big price. Every thing I dont want in a saw
I can get a referbished homelite 16 inch 38 cc with anti-vibration handle for 78.00 & 7.00 ship with 90 day warranty.
or brand new for $110.00 amazon.com if you run it at 30:1 oil ratio, it will last forever or until the carb craps out,which ever occurs first.
Oct 07, 2013 | Homelite Garden
New spark plug plus new air and fuel filter. Chainsaw will not start or even fire.
If there is a good spark and fuel getting to the plug there are only two reasons why it will not fire, sheared flywheel key knocking the timing out, or it has partly seized and has low compression.
Aug 09, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Saw will not run or start...set ignition module gap, disconnected kill switch wire because there was no spark...Put in new spark plug, got spark..Primed for gas and set choke as per instructions...Would...
Often the cause is a failed fuel pump diaphram. Rebuild the carb... kits about $20. The diaphram works from engine vacuum pulses. Also the little flap type check valves go bad... the ethanol in gas doesn't help this problem...
Sep 03, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
My chain saw will not start model #3314 14 inch I followed the directons on saw yet it will not start I also have the manual and followed the directions
How many hours on the unit?
Does it have spark?
Is it getting fuel?
Check the compression. If it has low compression it won't start.
Jul 05, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Saw has spark,compression,and fuel will not start
if u but fuel 5 ml in to cilinder and not starting then is problem in spark. if it starts and stop agein then is problem in garburator.
Mar 03, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I got a new poulan 33cc chainsaw from canadian tire, sold for parts only as it was not working. But it is still new. There is plenty of compression, and I checked the ON_OFF switch (took it appart),...
quite possible. check the spark plug holder to make sure the coil is in there that connects the wire to the plug..if it is there, disconnect the kill switch and make sure none of the wires going to it are grounding on the case, it just grounds out the coil to shut it off , when disconnected you will have spark if the coil is good.....shut it off with the choke if ya start it
Feb 13, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Just got a homelite 33cc 14 inch chain saw, do you mix gas and oil on this chain saw?
Yes you do! The ratio is 50:1 fuel to oil. Be sure to use a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to use fresh fuel and mix the two in it's own container. Be sure to shake the container thoroughly each time just before refueling to prevent oil starvation in the engine. Don't make up more than one gallon at a time unless sawing is your business. Hope this helps!
Dec 15, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
What is the mix for my Homelite 16" 33cc chainsaw?
50:1 is the fuel to oil ratio. Never use petroleum oil (engine or boat motor oil). Always use a synthetic saw oil available from home centers, hardware stores and saw dealers. The bottles are usually graduated to various ratios for a gallon of fresh gas. Always premix in it's own container and shake the container thoroughly each time just before filling the tank to prevent oil starvation. Be sure to use bar/chain oil for the chain as well, and keep the chain sharp and well adjusted. Hope this helps!
Nov 14, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
What is the oil to gas ratio for a homelite zr 10926 16 chain saw
This is a current Homelite product although not your saw. This clearly recommends 50:1 as do I. I find no OM for your saw, a "Ranger 33cc 16" Chain Saw UT-10926"
http://www.homelite.com/product_manual/file_url/66/UT10540_60_80_QSG.pdf
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1 and have for a number of years.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
I suggest you contact Homelite and request an OM for your saw.
Homelite/Ryobi.com (Contact Us)
https://register.homelite.com/contact_us/new
Please ask they prove a link to a site where ALL homelite product OMs may be accessed.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 06, 2010 | Homelite ZR10926 16 Chain Saw
My polan 14'' woodshark will not start. i changed the spark plug and ignition modual but i dont seem to be getting any spark
Try this it is most likely shorted wiring between the ignition and start switch.
Ignition Coil Test by SmallEng.com
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode. HTH
Lou
Sep 06, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Garden Logo
205 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
