Question about GE Dishwashers
Makes growling noises throughout the cycle.
Makes loud grinding/growling noises throughout the cycle. Quiet for 20 seconds, but then the grrrring starts. Works, but is very noisy. This is approximately a 3 year old GE Quiet Power 1 dishwasher which was included with the home we just bought.
  • 6,784 Answers
HI. here are the most common issues that will cause a noise during the wash.
* Check the spray arm for damage and obstructions
* Check the inlet filter screens
* Test the water inlet valve(see below for test procedure)
* Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
* Check the fan motor and blade
* Check the drain for obstructions
NOTE
If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
Posted on Sep 25, 2009
  • Michael Masters
    Michael Masters Sep 25, 2009
    To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first. If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
  • 67 Answers
SOURCE: noisy dishwasher
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
if this helps please vote me a fix ya
Posted on Jul 15, 2008
dutchman05
  • 487 Answers
SOURCE: Grinding noise from my GE Quiet Power 1 dishwasher
might have also something to do with limescale build-up in the washer arm itself.
Makes ballance off and can creat the noise. If it is clean you might check the filter and pump for any dirt build-up
Posted on Nov 29, 2008
  • 71 Answers
SOURCE: loud noise during cycle MDB6600AWB Maytag Quiet Series II
look for odjects in the pump cutter ie glass plastic or the cutter is bent or a rushing sound could be motor bearings
Posted on Dec 24, 2008
pappapumpdaf
  • 635 Answers
SOURCE: I have a GE GLD5860L15SS Quiet Power 2 dishwasher.
Sounds like a motor overload switch. You may have a bind on your motor or a clogged water pump. Try removing the kick plate and take a look underneath. You'd be amazed at what can end up under a dishwasher.
Posted on Mar 07, 2010
  • 17 Answers
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Posted on Nov 05, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
    In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
    Oct 18, 2010 | Xerox Phaser 6360DN Printer
    When washer is started make loud grinding noise
    Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
    Reply back and we can you more.
    Dec 13, 2009 | Dishwashers
    My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
    Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
    Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
    Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
    No longer "ultra quiet" huh?
    A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
    Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
    Aug 30, 2009 | Frigidaire Dishwashers
    On startup printer growls
    Hi Charlie, These machines have a history of growling, however usually they growl before changing the fuser. The fuser is most likely the problem maybe you got a bad one. If you still have the old one and it was quiet you could pop it back in to confirm. Ther is also a gear kit available to replace the fuser drive gears but usually the noise is in the fuser.
    Another growling noise can come from optional tray3 if installed. Easy to diagnose just lift machine off the assm. and print.
    Hope this helps
    Mar 19, 2009 | HP LaserJet 2420dn Printer
    1 week after installation- is very loud
    dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
    Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
    Dishwashers Logo
    752 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Oloyede Monsuru
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
