Question about KitchenAid KGST307 Gas Kitchen Range
I have a kitchen aid model kgcg260sob3 front burners wont light without a match
The front 2 burners on my kitchen aid model kgcg260sob3 will not light with the pilotless ignition. It is clicking but will not light. I have to use a match 2 light both of these burners. Any help would be appreciated.
Thanks
Tisha
    Sergeant:
  • 415 Answers
It could be the electrodes or the burner itself. get a technician to check it.
Posted on Sep 13, 2008
2 of my 4 burners on my Magic Chef Pilotless Ignition oven/stovetop no longer ignite - I need to do it by hand. Every once in a while one works but mostly neither will light up - other 2 work fine. Do
If you are seeing sparking coming from ignitor then it would be more likely that the ignitor has gotten out of position and would need to be put back to proper positioning. If the ignitor is not sparking then you would want to get a new ignitor. Here is the ignitor to order.
There is a video on that same parts page to show you how to make the repair.
Dec 09, 2013 | Maytag CGR1425AD Range
Gas is not coming through in oven
follow this test and fix it. God bless you
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Nov 05, 2013 | Kitchen Ranges
How do i turn the pilot light off. I want to use a bug fogger in my apartment and i want to temporarily turn off the pilot on my stove
This model should have pilotless electronic ignition.If you hear clicking when you light the burners , it is electronic,. Also , open broiler drawer and turn on oven .After a few seconds do you see a glow start?Thats your electronic oven igniter confirming you have no pilot.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
Hi, My GE Monogram ZDP30N4HSS range is making a
First I would replace both front igniters thier about $20 a piece this should fix the clicking. They keep clicking because they are not sensing the flame. The front burner assemblys will need to be thoroughly cleaned. There are very small orfice holes that need to be spotless. Also the burner cover, the top piece that pulls off. Make sure the bottom lip is very clean. Use a fine wire like a paperclip to clean out the holes in the burner assembly. For diagrams or illustrations enter your model # at www.appliancehelponline.com
Sep 08, 2010 | Whirlpool RF364 Electric Kitchen Range
Oven burner won't ignite
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 19, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
I have a gas range, pilotless ignition. Burners work but oven will not heat
hi,
This problem is usually because your burner is not staying on continuosly because of a weak ignitor.
Check out this tip
Oven not Working or Oven not Heating http://ping.fm/mEg1i
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Jan 23, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
JennAire Gas Range - 2 of 4 burners don't light
I had same problem and believe it or not it was caused by a Blue Rhino Propane tank. It was a new exchange tank and because of their "safety" features it would not release a sufficient amount of propane to heat with. Switched tanks and all burners fired up. Have found others on the web with same problem and solution.
PJ
Apr 06, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
210 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
