Question about Directed Electronics Dei '96 To '98 Jeep Cherokee Remote Start Interface Module
My 98 jeep starts and runs but sometimes idels down almost dies then idels way high like a serge i checked the altinator and battery then changed the coil what else could it be
  • 32 Answers
Intake manifold sensors........ check any plug/ wire that goes to any of the intake sensors
Posted on Oct 05, 2009
Lincoln continental battery keeps dying
the altinator should be putting out at least 14 volts,so have it checked out,and if its dead after an hour or so,it sounds like the diode,s gone,so the problem does seem to be the altinator.
Jul 02, 2012 | 1998 Lincoln Continental
The tester says the altinator is ok but after time the battery dies and the brake and engine light comes on it is a legacy wagon i think it is around a 97-98. the lights still work btu car dies driving...
There were a few years that they built the voltage regulator in the ECM. If it has gone out then this is the problem. The alternator can be good but the regulator is not letting the charge threw to the battery. This is some thing you will need to check on. There also could be an external regulator for your year, it is old enough. Hope this helps you.
Aug 04, 2011 | Charging & Starting Systems for Subaru...
My 2002 jeep wrangler check gauges light came onand the battery gauge is below the left dot on the gauge. does that mean i have to replace the battery?
With the jeep running put a volt meter on the battery and it should be reading above 13 volts if not replace the altinator it isn't charging.You can check the fuse for the altinator first if not charging but most likely the altinator is bad.
Jan 31, 2010 | 2002 Jeep Wrangler
During driving and ideling the engine simply dies,
sounds like your crankshaft sensor is faulty.I would change that first.
Jul 17, 2009 | 1998 Jeep Grand Cherokee
Having trouble keeping my 98 jeep grand cherokee running
i recommend cleaning the throttle plates. they are located unter the intake hose form the engine to the air filter housing. if you open them with the engine not runniong you will see they will be covered in carbon. use a good carb cleaner and a rag to wipe them clean
Jan 20, 2009 | 1998 Jeep Grand Cherokee
No spark/wont start
i have a 98 and it has a distributor but it could be a fuel issue more than a spark if you have a fuel pressure gauge and check it.should be above 30 psi to me it sounds like a fuel pump thats bad
Jan 19, 2009 | 1998 Jeep Grand Cherokee
Clicking sound when trying to start 1987 jeep cherokee.
Probably is the electrical side. Start your vehicle, with the engine running disconnect the positive battery cable. If the engine dies then your alternator is the problem, if engine continues to run the battery is at fault.
Nov 21, 2008 | 1987 Jeep Cherokee
2004 Jeep wrangler
try the altinator
run the car take positive of if the car runs altinator is good
if the car dies the altinator is dead
aslo check how old battery is and the top up levels
Jul 24, 2008 | 2004 Jeep Wrangler
Directed Electronics Dei '96 To '98 Jeep Cherokee Remote Start Interface Module Logo
69 people viewed this question
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
