Question about Panasonic Lumix DMC-FX35S Digital Camera
Spot showing on pictures and can be seen through viewfinder. Lens appears to be clean on outside.
    Scholar:
  • 96 Answers
Could be a pixel out on the CCD (part that records the picture) or a bit of grit, turn digital zoom on, zoom till digital zoom is just enabled (first marker), then take a picture of white wall/paper, digital zoom fully, take another picture. If the spot has moved then it is the CCD, if it hasn't then it's in the lens. If it's in the lens, take white pictures but give the unit a gentle tap between pics, if it moves it's a piece of grit. Either way it will need to go for servicing. A faulty pixel can be "remapped".
Posted on Sep 27, 2009
Pictures didnt develop
Hi Steph Johnson,
Numerous things could be the issue. 1, dirty lens, clean the front and back element, 2. The camera focus is not working properly not focusing on the correct spot. So, are you manual focusing or auto focusing? If it is auto then there could be an issue with that. If your are manual focusing are you sure your diopter setting is correct for your eyes, if not then it may appear correct in the viewfinder, yet be off focus.
Do you have a way to check the lens on a DSLR? If so you can try that lens on the DSLR seeing if there is an error with the lens or if it is your film camera.
Cordially
Oct 20, 2013 | Canon EOS Rebel XS 35mm SLR Camera
Fujifilm Finepix S5700 - spot appearing in viewfinder and photos
Have you change lens sense this problem. Could be a glitch in the software of the camera.
Oct 15, 2012 | Fuji FinePix S5700 Digital Camera
My pentax k1000 has a black splotch in viewfinder, does not show up in images.
It would depend on exactly where the splotch is. If it's on the outside of the viewfinder, you could simply clean it off with a damp cloth (and maybe some Windex or Formula 409). If the eyepiece is damaged, you can order a replacement part here.
Remove the lens and look at the mirror. If their is something on the mirror, you can carefully clean it. The mirror is very sensitive and vulnerable to scratching. If the reflective coating has been removed then you'll need a new mirror.
Look up at the bottom of the focusing screen. That's the more-or-less clear piece of glass that the mirror will reflect light from the lens onto. If there's a splotch on the outside, you can clean it off.
Those are the parts you can get to. If the splotch is on something on the inside, then you'll have to take the camera to a good camera shop to have a trained professional disassemble and clean it.
May 23, 2012 | Pentax K1000 35mm SLR Camera
I have a Olympus C-750 UltraZoom. I was taking pictures and everything was normal, but then I noticed the viewfinder was blurry. I was walking through a tunnel under a river and I thought the temperature...
Hi Steve, I inform you that the problem only is moisture. Please follow this.
1. Put the camera in sunlight for few hours. After that use it & if you face same problem then
2. You need to visit camera repair shop and they open the camera completely and clean all the inside part of the camera. because you need to clean the moisture inside of lens, viewfinder & sensor too.
So only hope in sunlight. If its solve then fine.
Jan 21, 2011 | Olympus Camedia C-750 Ultra Zoom Digital...
Pentax SMC D 16-45 Lens How to clean inside? Pictures are showing spots and all the outside lens have been cleaned along with the inside of the camera itself. Can not see the spots when taking pics only...
Your lens would need to be absolutely filthy with enormous dirt specks to cause the fault you describe. Dust, fingerprints, and regular minor debris simply doesn't show in the final image. In any case, you cannot clean inside the lens without dismantling it and that is a job for experienced specialists only.
Your fault is a dirty image sensor. You can buy sensor cleaning kits, but if you're inexperienced with them or trying to clean the sensor in a dusty environment you'll just make matters worse. Many camera shops offer sensor cleaning while you wait at relatively low cost. The reason you don't see the dirt when taking the picture is either because you're looking through the optical viewfinder or because the LCD screen simply doesn't magnify the image enough to show the marks which are present in the image.
You can prevent the dirt from reoccurring by never leaving the camera with the lens throat open for more than strictly necessary, and by always trying to keep the open lens throat pointing slightly down when swapping lenses.
I hope that I've helped, please take a moment to rate my answer.
Sep 16, 2010 | Pentax *ist DL Digital Camera
A hair like object seen through the viewfinder.
Hello
Thank you for using FixYa for your problem
there is some hair/dirt in the viewfinder, above the lens
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Rollei QZ35W Point and Shoot Camera
Minolta X-370 Spot driving me nuts!
If its inside the viewfinder, then you'll really need to take it in for a repair, but bear in mind, that will require disassembly and that will likely run you $75-$100, which is more than a used X370 goes for on eBay.
One thing I would check is the underside of the focussing screen as maybe it is on there. Remove the lens and then look thru the viewfinder. If you still see the spot, then its in the body and not in the lens.
Look inside at the underside of the prism - thats where the focussing screen is. Do not touch the screen with any cleaning fluid or your finger. instead, grab something fairly stiff but pliable, like the straw on the edge of a dust blower. and gently rub the general area on the screen where the spot might be. Then blow the area with air to clean it all up. Look thru the viewfinder again and see if that got it.
Its pretty rare for dust to get inside the viewfinders unless they had previously been open for a repair, so theres a good chance its stuck to the focussing screen. Don't touch it with solution or your finger though as the screen can be damaged easily.
Dec 29, 2008 | Minolta X-370S 35mm SLR Camera
Spot appears in pictures and LCD display.
That's a good bet, I think the service centers will do this as an
"annual internal cleaning" although I don't know what they will charge. Taking apart the optics is challanging and risky.
Jul 01, 2008 | Fuji FinePix F20 Digital Camera
Panasonic Lumix DMC-FX35S Digital Camera Logo
136 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
