Question about Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500
I have a 3 speed fan switch. The wire colors are red, black, blue
And black. I bouight a replacement switch- wu-pin E198635 by westinghouse. (old switch wiring was L -red, 1-black, 2- blue, 3- black:.
The no. 1 black wire connected to a 5 watt resistor ;and # 3 black wire appeares to be the hot wire). The original switch was a JIN YOU # E70489. Are these 2 switches compatible?
3 Suggested Answers
  • 351 Answers
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Posted on May 25, 2010
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
SOURCE: chain broke on jin you
Try following link, without guarantee: It has same number but says 4 wires
http://www.allelectronics.com/make-a-store/item/PSW-14/PULL-CHAIN-SWITCH/1.html
You posted under Westinghouse:
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
Internet search does not show 5-wire switch, they are either 3 or 4 wire.
Maybe you have older fan, or maybe the switch can be replaced with 4 wire.
Next step would be to test your wires to see if 4-wire conversion can be made:
Determine which wire is hot if possible.
Take photo of wires and then remove switch.
Use multimeter set to read ohms, and test between each wire and the wire you labeled hot wire.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Posted on Aug 02, 2011
How do I replace pull chain on old hunter fan. No replacement available Home Depot gave generic switch. I don't know what wire color goes in switch L 1 2 3 Wire colors are red black blue
If that's a two speed hunter, you have the wrong switch. You need to get a two-speed switch. This switch comes with the wires attached. Do you have the fan model?
Mar 15, 2015 | Hunter Dryers
Do not know color coding for ceiling fan speed control witch WU Pin 198635
How many wires on capisitor? Black usually goes to L. Should write this down before removing switch. You can't buy any swich off a rack and expect it to work even if it looks the same on the outside.
www.fanfairceilingfans.com
Mar 20, 2013 | Dryers
My old ceiling fan capacitor has A B C D on the back , the new capacitor has 1 2 3 4, how do I connect the new one????
I just changed out an old ADCB (172-90-001 / 1-81-M) fan speed switch with a L123 3 speed switch (Westinghouse 77286). My fan was only 2 speed but the 3 speed switch was all the Home Depot had in stock. So I knew I would have OFF occurring twice in the pull sequence. Its an old Hunter fan that came with the house.
A-Unused
B-Went to 1 (Blue Wire)
C-Went to 2 (Red Wire)
D-Went to L (Black Wire)
I originally put B (the Blue Wire) into spot 3, leaving 1 unused. But that made the pull order go OFF-OFF-LOW-HIGH.
So moving the Blue Wire to the 1 slot resulted in OFF-HIGH-LOW-OFF
Hope this helps!
Apr 01, 2012 | Dryers
Fan switch are LJY-280A and E198635
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Feb 21, 2012 | Hampton Bay Dryers
I have a westinghuse fan with light it has four wires on it green, blue, black, and red what are they ie live neutral etc
Question posted under 3-speed switch
1) Are you replacing the 3-speed switch?
This is a field with much discussion because Westinghouse 4-wire fan switches vary.
Process of elimination is needed to find hot line. From there you test each wire to the hot line wire to determine which wire or combination of wires makes up low, medium, and high speed.
Open following links for some resources:
http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
2) Or are you looking at fan connection wiring at ceiling?
Green wire goes to bare ground.
Fan should have hot and neutral.
Hot line should be black.
Neutral should be white.
Red usually goes to light
Blue is normally not there.
Where is the white neutral wire?
Take multimeter set to read ohms and test black wire to each other wire.
Process of elimination should reveal correct wiring.
Aug 21, 2011 | Speed Ceiling Fan 3-speed Switch By...
How do you open a wu pin switch. the chain broke & went inside switch
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
Jun 13, 2011 | Westinghouse Electric Westinghouse...
Westinghouse Lighting 3speed Ceiling Fan Switch 7707500: I just replace the speed control switch in my Hunt...
Typically the old and new switches have no relative relationship to each other .. One way to figure this out is shut off the power and then using the black power wire attach each speed wire to it and turn power back on to observe the speed .. mark the wire with the speed 1, 2, 3, .repeat this untill all the wires are identified .. . then you can put the wires on the appropriate terminations on the new switch ..
questions ..
Please vote !
May 17, 2010 | Westinghouse Electric Westinghouse...
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Trying to replace 3 speed ceiling fan switch and don't know which wires go where - 3 speed fan switch, 4 wire unit.
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Aug 06, 2008 | Westinghouse Fans Indoor Ceiling Fans
Westinghouse Electric Westinghouse Lighting 3speed Ceiling Fan Switch 7707500 Logo
1,022 people viewed this question
Top Westinghouse Electric Electrical Supplies Experts
Gene Haynes
J Rosado
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
