Question about Frigidaire Refrigerators
ICES UP IN BOTTOM OF FREEZER AND WATER DRIPS OUT FREEZER DOOR
  • 324 Answers
Please defrost your freezer and check it
Posted on Sep 25, 2009
On our GE refrigerator, water leaks out of the bottom of the frame for the water/ice dispenser and down the front of the freezer side door. What could be causing this?
Did you just recently change your water filter? you need to flush 3 gallons of water out of it when changing the filter. if there is air in the line it'll drip constantly. If your ice door isnt closing all the way and properly sealing that also could be a source of water dripping. do you have a low of "Snowy" frost inside your freezer door at the ice dispenser shute?
Aug 05, 2013 | Refrigerators
Water is slowly dripping onto the floor from the bottom of the freezer door. it is as if the door is full of water. any suggestions?
ARe the temperatures good inside the freezer? If they are not near 0° F, that is the cause of the water drip.
If it is nice and cold in freezer, check freezer floor, is there a sheet of ice? you have a clogged defrost drain, clear it or have it cleared for you.
Good temps no ice on freezer floor? possible water leak inside door from water dispenser
Aug 13, 2010 | GE GSH25JFR Side by Side Refrigerator
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
I have a top freezer model and every morning their is a small pool of water in front on the floor. I checked the bottom tray in the back and drip tube and they seem to be ok. I noticed in the door that...
These doors are not water cooled. Is there water in the drip pan? Likely not and the drain is froze over with ice. you will have to remove the rear panel inside the freezer and clean the drain. There is most likely ice under the freezer floor that needs removed also. Take your time and do not damage the styrofoam separator and air channels.
Eric
Aug 27, 2009 | Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerators Logo
15 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
