Question about Kitchen Appliances - Others
Help! My top of the range coolskin shaver (bought May 07) has stopped holding its charge - any ideas?
    President:
  • 1,714 Answers
Needs a new battery. Take out the old one and get the rating (volts and mah) mah =milli amp hours. Go online and get anew battery. Good as new!
Posted on Oct 03, 2009
My philipshave coolskin shaver doesn't work after it has been charged. when it is on the charging stand the green light is showing that it is being charged. Please help!! Ry
Your battery pack is probably dead and needs replacing. You will find the correct battery for model 5605X at shaveroutlet.com. See link below for item and also scroll down item page for installation tip videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Aug 13, 2011 | Philips Philishave Cool Skin HQ6760/HQ...
Help please. My Philips coolskin works fine but has various lights come on and go off. When switched on the amber light above the charging point comes on and stays on. The shaver head light flashes red for...
When the shaver head light flashes, this indicates that the heads should be changed. You will need the specific model number written on the shaver to select the correct type heads
Jun 09, 2017 | Philips Philishave Cool Skin HQ6760/HQ...
I can't get my Philishave Coolskin to accept a charge. Pretty sure that the charger is working as I was getting the red charge light but didn't get the green bar indicators as it charged. Any ideas
Most likely, the battery needs to be replaced. The symptom you describe would suggest this.
You can purchase a replacement battery pack for model HQ6740 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To change batteries you will need to remove the lotion packet cover on the back and then remove all of the screws on the back to remove the back of the case.
For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
May 10, 2010 | Philips Philishave Cool Skin HQ6740...
I lost my Philips Coolskin 7775X shaver charger.
philips norelco 4222-039-10972 adapter charging cord for electric shaver norelco 7775x power cord replacement parts.
Oct 23, 2009 | Philips Health & Beauty
I have a Norelco Coolskin 7775x that has the 3 head red light on, I replaced heads, now how can I reset the light off?
Common problem on this shaver. Norelco customer service says if you let the shaver run down until the battery is dead and then recharge it, the unit should reset and the red light will go away, but this has not worked for me. I just ignore the light...
Sep 09, 2009 | Norelco Cool Skin 7775X Electric Shaver
Philips shaver not charging
The batteries are soldered to the circuit board with solder tabs. These are not standard chargeable batteries that can be bought at the corner hardware store. The are Lithium Oxide based batteries with solder tabs. These should be replaced by an experienced tech. The replacement batteries must be to spec of the original ones. There is the current rating and voltage rating of the batteries to matched.
Because these chargeable batteries can put out a strong amount of current, if they are not installed properly, there can be safety issues.
Call Philips tech support to be advised about where you can take the shaver to have the batteries changed.
Jerry G.
Apr 17, 2008 | Health & Beauty
Charging stand
I just had the same problem, where the top of the charger would not stay down. I tried a spring clamp to keep it in place, and that works like a charm! Try it!
Aug 19, 2007 | Braun Syncro 7680 Electric Shaver
Kitchen Appliances - Others Logo
52 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
