Question about GE 24 in. GLD6200L Built-in Dishwasher
No water coming into the dishwasher - GE 24 in. GLD6200L Built-in Dishwasher
  • 6,784 Answers
HI. this is a water inlet valve issue. i recommend testing this device. it may be faulty.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first. If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
**(((If the inlet proves to be functional with no leakage, this will lead to the control. its has failed in thsi case. replace it asap)))
Posted on Sep 25, 2009
Water will not come in to my dishwasher The
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Feb 22, 2011 | Kenmore 13599 / 13594 / 13592 Built-in...
My dishwasher wont fill up with water it does come on and makes a noise but no water
Dishwasher Trouble
heatman101
Feb 13, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water not coming into dishwasher, motor keep running
Dishwasher Trouble
heatman101
Jan 06, 2011 | Viking 24 in. Professional Series VUD141...
Water does not come into the dishwasher. can hear the pump, the heater works, the indicator lites illuminate, but water does not come in. The water supply is hooked up and turned on, there is good flow...
Usually the problem is the soleniod valve that lets the water into the dishwasher...
here is a tip that I wrote that gives many more details about this problem...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 21, 2010 | Dishwashers
No water going into to dishwasher all of the sudden.
check water connection to bottom of dishwasher (left hand side) if you have water going into the valve but no water coming out of the valve theres the problem check to also see that you have power to the valve
Apr 29, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
It runs but the water is not coming into the
Check connection under sink to ensure sediment is not blocking inflow. You will need unplug, shut off water valve, then disconnect hose from water source and check for blockage due to buildup of minerals/hard water. Make certain first that flexible dishwasher intake hose is not kinked..
Nov 27, 2009 | Miele Slimline G832SCi Built-in Dishwasher
Dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Nov 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
GE 24 in. GLD6200L Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
