Question about Ricoh Aficio MP1600SPF Copier
Where e is the location Gestetner 2722ztd parts 1. thermistors 2. Fusing heater 3. Thermostats Please locate the location of the above parts of the machine clearly if it possible Show me with picture Think u in advance
  • yibeltal f Oct 01, 2009
    thank u for ur technecincal support,but still i dont know the location of
    1. thermistors
    2. Fusing heater
    3. Thermostats
    in Gestetner 2722ztd
    can u visualized agian
  • 143 Answers
It is inside the part that gets REAAALLLL hot!
Posted on Sep 25, 2009
Copier Gestetner Dsc530 (or Ricoh Aficio mp c3000) has error SC501 - tried to reset, but need to replace thermistor. Can't find a diagram on where it's located on the fusing unit. Anyone?
Error code SC501 is not a fuser problem. It is the top paper feed tray. Take all of the paper out of tray 1 and turn the machine all the way off. Turn it back on. Code should be cleared. If it returns with no paper in it the paper feed station has a broken part and can only be repaired by replacing it.
Nov 04, 2013 | Gestetner Office Equipment & Supplies
Hi.. please help me.. my minolta dialta 183 is not working.. there's a code CO5 in the screen.. please help me to fix it.. thanks
C0500: Warm-up failure
Step 1
Check:
Fusing Heater Lamp (H1) turns
ON.
Step 2
Check:
Fusing Heater Lamp (H1) is open-circuited.
<Check Procedure>
Check the resistance across both
ends of the Fusing Heater Lamp
(H1).
The Fusing Heater Lamp is open-circuited
if the resistance is infinity.
Result: YES
Action: Change Fusing Heater Lamp (H1).
Step 3
Check: Thermoswitch 1 (TS1) is operational.
<Check Procedure>
ends of the Thermoswitch 1 (TS1).
The Thermoswitch 1 is open-circuited
Result: NO
Action: Change Thermoswitch 1 (TS1).
Step 4
Check: Fusing Unit Interlock Switch (S2) is
operational.
<Check Procedure>
Check continuity across terminals
when the Fusing Unit Interlock
Switch (S2) is turned ON.
• Across S2-1A and S2-1B
• Across S2-2A and S2-2B
Result: NO
Action: Change Fusing Unit Interlock
Switch (S2).
Result : YES
Action: Change DC Power Supply (PU1).
Step 5
Check: Thermistor (TH1) is open-circuited.
<Check Procedure>
Check the resistance across CN15-2
and CN15-3 on the Fusing Unit side
with CN15 disconnected.
The Thermistor is open-circuited if
Result: YES
Action: Change Thermistor (TH1).
Step 6
Check: The following voltages are supplied
from the Master Board (copier: PWBA).
<Check Procedure>
Check voltage across a Master Board
(copier: PWB-A) pin and GND when
the Power Switch is turned ON.
• Voltage across PJ10A-7 and GND
DC24 V when Fusing Heater Lamp
(H1) is OFF
DC0 V when Fusing Heater Lamp
(H1) is ON
• Voltage across PJ10A-10 and
GND
(H1) is OFF
(H1) is ON
Result: NO
Action: Change Master Board (copier:
PWB-A).
Oct 05, 2011 | Konica Minolta DiALTA Di200 Copier
Minolta dialta 183 help me... theres a code in the screen CO5 .. and automatically turn off.
Step 1
Check:
ON.
Step 2
Check:
<Check Procedure>
(H1).
Result: YES
Step 3
<Check Procedure>
Result: NO
Step 4
operational.
<Check Procedure>
Result: NO
Switch (S2).
Result : YES
Step 5
<Check Procedure>
Result: YES
Step 6
<Check Procedure>
(H1) is OFF
(H1) is ON
GND
(H1) is OFF
(H1) is ON
Result: NO
PWB-A).
Oct 05, 2011 | Minolta DiALTA Di183 Copier
Gestetner 3225 error code SC544 - functional problem
SC544 indicates low fuser temperature during the warm up process. This means you have a problem with the fusing unit heating up. The fusing unit is located right where the paper exits the machine. Most common failure on these Ricoh's (Your Gestetner 3225 is made by Ricoh model aficio 250) is the fuser thermistor. This is a small electronic part that measures the temperature of the fusing roller. When they go bad they do not "see" the heat and therefor the code pops up. You are going to need to have a tech look at this for you as you will need to determine for sure which part is bad then you have to go into the service mode to reset this SC code before the machine will run.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Gestetner Copier
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
Photocopier comin up with error sc550 on gestetner 1302
The problem in the fusing unit.Clean and verify the heater lamp,thermistor and thernofuse continuity.
Sep 26, 2009 | Gestetner Office Equipment & Supplies
Error SC541 ON NRG MP 1600L
First try entering into SP mode by pressing:
Clear button>1 0 7> and press and hold the Stop button for 3 secs. Then switch off and on the copier.
If SC 541 code is still there, check the following in the fuser unit:
  • Fusing thermistors defective or out of position
  • Thermostats open circuit
  • Power supply board defective
  • Loose connectors of Fuser unit.
Good luck and please rate me, thanks.
Feb 26, 2009 | Gestetner DSm615 Digital Imaging System
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Functional problem code SC542-00
Enter SP mode > Clear (yellow) button > 1 0 7 > and press and hold the Stop (red) button for 3 seconds.
Then switch off and on the machine.
If error still there, probably you have a problem in the fusing unit.
Possible causes are:
Thermistor defective;
One of the fusing lamp is open circuit;
Thermofuse open;
Fusing unit connector defective; and
Power supply board.
Jan 21, 2009 | Gestetner Copier
Ricoh Aficio MP1600SPF Copier Logo
104 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
