Question about Polaroid TDA-03211C 32 in. LCD HDTV
Only red light glows when the tv is turned on
TV WILL NOT TURN ON AND RED STATIS LIGHT IS ON NO CODES ARE SHOWN. WHAT DO I DO?
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp. Keep in mind that some off-brand lamps may only last a few weeks, so replacing a relatively new off-brand lamp may unfortunately be necessary.
Apr 04, 2015 | Mitsubishi Televison & Video
Frigidaire oven FGB24L2ASA. Igniter glows red, gas turns on, but does not light.
I appreciate your inquiry, K Ogle!
From what you have described about your Frigidaire range the igniter glows red and the gas turns on but it will not light. It sounds like it could be a faulty burner or igniter and I would recommend having a professional come out to properly assess your range. This does not sound like a simple DIY job. Good luck. -Matt
Feb 17, 2015 | Frigidaire Kitchen Ranges
Blank screen panasonic plasma tv
The solid red light and the glow of the screen indicated the set is on . also if set is on a red light should be emmiting from the optical out jack. Seem like you have lost audio and video. If no menu appears when pressed on remote the replace the main board. Panasonic calls this the A board.
Jan 06, 2014 | Televison & Video
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to ...
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position ,please to help of rectivied this problem and send circuit diagram and IC pin configaration thanking you sir
Mar 03, 2011 | Televison & Video
TV red spot
Your light engine is going bad.
May 12, 2009 | Hitachi 51F59 51" HDTV Projection...
Tv fails to power on red light glows around power button on tv
there is somthing like puse in the back in side it cost u near about 200 $ put that it gone work 101percent
Dec 12, 2008 | Samsung HCN4226W 42" Rear Projection...
Pioneer rear screen projection tv model #sd p6091-k when i push the standby button in on the front the little standby light glows red like it should but when i push the on button it should turn on and glow...
wait a minute you wanted me to pay you to tell me how to fix it... now you want me to tell you how i did it ...no thanks ...well for 9.99 a month ill tell you...no thanks
Nov 08, 2008 | Televison & Video
Polaroid TDA-03211C 32 in. LCD HDTV Logo
46 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
