Question about SanDisk Sansa e250 MP3 Player
I bought a sd card for the sansa and I need to know how to load music onto it.
    Problem Solver:
  • 8 Answers
It will do it automatically when installed
Posted on Sep 25, 2009
Replaced SD card now Shaker won't play
Hi Cathi!
Few things you need to know about Sansa Shaker and the SD card:
  1. The Sansa Shaker DOES NOT support SDHC memory cards. Only regular SD cards are supported.
  2. Maximum capacity for supported SD cards - 2GB!
  3. Any SD card which doesn't meet the requirement above might cause the problem you encounter. REPLACE the card with a supported one - SD card with up to 2GB in capacity.
  4. No software/data is stored or needed to be on the memory card - apart from your music files.
  5. MP3 file type is fully supported by Sansa Shaker.
Regards,
Pelu.
Apr 10, 2010 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
My sansa player does not recognize a micro sd when its inserted
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Cannot upload to micro SD card
make sure the card is 2gb if it is just try dragging music in too the folders, you might have to format the card first
Dec 30, 2008 | SanDisk Sansa e250 MP3 Player
Added 2GB micro SD to Sansa e280, computer doesn't recognize
There are 3 ways to solve your problem, but all of them are rather kludgy. This is an old player and the integration of the microSD card is not done very well. I believe with the newer players these sorts of issues are not problems. Anyway, here are your 3 possibilities:
1) You can load your music directly onto the card before you put it into the player. Most cards come with an adapter that lets them fit into slots that are for regular SD cards. So if your computer has a slot for an SD card (or if not, you can plug the card into a card reader and then plug the card reader into the USB port on your computer) then you can copy and paste mp3 files onto the card. This is a drag because you can't use Windows Media Player to do this, but instead need to open the folder where the MP3 files are and then copy and paste them onto the card. But it works
2) This is slightly easier. Before you connect the Sansa player to the computer go to the settings part of the main menu and then select mode. You should see two choices. One is MTP and this is the setting you want if you are using the player with Rhapsody service. The other setting is MSC and this lets your computer recognize the Sansa player AND the microSD card. Once you have selected the MSC mode, then you can connect the player to your computer. When you look at the drives on your computer, you'll see 2 new drives. One is the Sansa 280 and the other is the microSD card. Once you see those, you can copy and past MP3 files right onto the card (and/or onto the Sansa). Again, you have to go the folder where your MP3 files live and cannot use WMP to do this
3) I haven't tried this, but others say that a free program called rockbox (www.rockbox.org) let's all this work much better. It sounds complicated, as it puts kind of a new operating system on your Sansa and it may not be reversible, so proceed with caution, but some people love it.
Hope that helps
Dec 28, 2008 | Samsung YP-T8 Digital Media Player
More memory?
I haven't tried this, but I see no reason it why it shouldn't work. I have used an 2gb expansion card in my Sansa and it works just fine. The only problem is it will only play music off of an SD card, no video. I guess this is only to much memory if you don't need it. Rough guess is that a 4gb will hold roughly 1000 songs. I would only go for the smaller sd card if there was a substantial price difference and you won't be needing the extra space.
Dec 06, 2008 | SanDisk Sansa e250 MP3 Player
Write protect
The Sansa e260 can only use microSD cards. I believe the 4GB model can only handle the 1 or 2 GB cards. If you try to do any SDHC ones, then you may run into problems. I suggest right clicking the SD card on your computer screen after it pops up. Select Properties. There can be some help in this area. I suggest going to tools, and check for error problems.
Jul 17, 2008 | SanDisk Sansa e260 MP3 Player
How do i put songs on the mini sd card i bought for my Sandisk sansa connect mp3 player
I'm not sure but you should be able to find the settings for saving data in it's menu and change the location from internal/onboard to memory card.
I hope this helps, and Good Luck.
Jan 23, 2008 | SanDisk Sansa Connect MP3 Player
Sansa c250 sd card installation
yes i have the same problem how do i get the music onto card itself
Jan 10, 2008 | Audio Players & Recorders
Expandable Memory
If music won't load onto Micro Sd card:
1) go to settings
2) go to USB mode
3)change to MSC format
Now you're good to go.
Nov 03, 2007 | SanDisk Sansa e250 MP3 Player
Sansa c240 and memory card
When you look at the media player (i assume you're using Windows Media?) you should see a pane on the right side. In blue font near the top it should say "Next Device." Click that and it should bring up the SD card to sync to it...Also, you could get an SD reader and do it that way...
Oct 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
