i have a lennox gas furnace and every time i lite the pilot the heat starts and runs good for 2 hours and then both heat strips and pilot lites goes out again
Comments:
Dec 23, 2007
- this furnace has gas heaters and not elecricheat strips sorry
Dec 23, 2007
- yes i meant burners and yes it runs for 2 hours straight and then shuts off i have the thermostat turned up to 90 degrees
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Comments:
Dec 23, 2007
- Thanks for the clarification, First we ned to start eliminating the culprits. As this is an intermittent problem, meaning it works and sometimes it dont work. So lets start with the thermostat. remove the cover to expose the wiring. You should see red=power, white=heat, green=fan and yellow or blue=cool. make a jumper wire or remove one of the wires whichever is easiest, and connect the red to the white. Dont be afraid of being shocked you probably will not feel anything, just be careful not to touch anything else with the wires, because it may short out the transformer. If you will be more comfortable cut the power. Anyway this will by-pass the thermostat and the furnace will run continuously. If the heat doesn't cut out, that's it, replace 't'stat. If you have the problem still then, we need to look at the limit control or thermal disc if you have one. Lets try this first and let me know.
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at...
(More)
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at the lowest price. We stand by and guarantee the quality of our laptop battery.
<a href=http://www.bestlaptopbattery.co.uk/hp/dv1000.htm>Hp dv1000 battery</a>
Our Price: At Bestlaptopbattery.co.uk, you always pay the lowest price. We make this sure by offering our Best Price Guarantee on all our Hp dv1000 laptop battery.
Our Service: We have a dedicated team of customer service executives who are eager to help you save time and money by sharing their knowledge and expertise on batteries and related products.
Your Satisfaction: Your absolute satisfaction is our top objective. We stand by the quality of our battery and offer a 30-day money-back guarantee on all our products, no questions asked. Our products also carry a 12-month full repair or replacement warranty for any form of manufacturing defects.
How can you care Hp dv1000 laptop battery to get the maximum life out of it?
It is a question we frequently asked. It's a valid question since laptop batteries are usually expensive to replace.
First of all, how long should your battery last? 2-4 years is generally acceptable depending on how frequently you use and charge the battery. If you travel a lot and use and charge your battery frequently then you might only get a couple of years at the most out of your laptop battery.
The Hp dv1000 laptop battery are usually made with Li-Ion laptop batteries and the very nature of Li-Ion batteries is that they have about 500-600 charges and last at most about 4-5 years (shelf life). They also have a self-discharge rate of about 1% per day so you need to be sure to charge them at least every 6 months.
we were going to purchase 2 fujitsu split systems, but have just had a offer of buying LG instead ....
(More)
we were going to purchase 2 fujitsu split systems, but have just had a offer of buying LG instead . where can we get info, not from a salesperson regarding whats the better unit, can u help
Hi I am searching for Fujitsu AST24RGB Circuit board as the ants and gekkos damaged the original....
(More)
Hi I am searching for Fujitsu AST24RGB Circuit board as the ants and gekkos damaged the original. Are they available and if so how do I go about getting one? The rest of the unit is fine.
my split system just blink a green light when turned on--outside powerboard was recently...
(More)
my split system just blink a green light when turned on--outside powerboard was recently replaced--worked ok for a while
