Question about Maytag EPIC MFW9700S Front Load Washer
Maytag has fo2 in display - Maytag EPIC MFW9700S Front Load Washer
Washer displaying FO2. What does this mean. Tenant called me I am out of town. Need to know what the problem is. Thanks!
F02 means its detecting a slow draining condition. The drain pump clean out is most likely clogged. This is located behind the front panel and has a removable cover.
Jan 13, 2011 | Maytag MAH8700A Front Load Washer
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code
Hello there
F/02 Long Drain
Nov 19, 2010 | Whirlpool Washing Machines
My washing machine is a hotpoint ultima and it is 4 years old . the drum is not spinning and an error msg f-02 is displayed
fo2 is a motor fault, possibly the motor tacho, brushes, broken wire to the motor or module board is faulty.
Apr 07, 2010 | Hotpoint Washing Machines
What does Fo2 S/S SW ON mean
What is the model number of the sewing machine?
Mar 18, 2010 | Brother Sewing Machines
Kenmore washing machine model 110 he3t code fo2
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl. rate me nice for the free help!
Sep 17, 2009 | Kenmore Elite 45986 Front Load Washer
FO2 Error Msg
ok now ,,check why water is not leaving machine on time,,,check your drain pipe,,check the drain hose,,just blow in it and make sure a coin not stck there ,,the same with the waste pipe,,onthejob
Feb 18, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FO2 code?
It was my wall plug that was the problem, used an extention and my machine fine now, Thanx
Jun 20, 2008 | Washing Machines
FO2 Error Msg
Hamish, F02 is long drain. Check that the drain hose is not kinked or plugged. Check the drain pump filter for lint and debris. Check the electrical connections at the pump and the fact the the pump is running. Make sure you are using HE detergent and that you are not over sudsing. Check the drain itself is not backing up. If all of the above are good, replace the pump...Catriver..post back.
Oct 10, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
