Question about Welding Tools
I have a leister Triac S that needs fixing is there an exploding diagram to assist in the repair an electric curcuit would help also,
3 Suggested Answers
shah92
  • 74 Answers
SOURCE: Please send me the curcuit diagram of Nokia 6680
Dear what is ur problum mention i will tell u solution there are lot of reparing methods for each fault.
Posted on Mar 27, 2007
SOURCE: 2001 Commodore electric window winder diagram
The car in question is a Holen Commodore, an Aussie vehicle. I have since sorted out the issue, replacing the slides that sit on rails within the door, I removed the remaining worn ones with a large screwdriver and the safest way to clip the new ones into place is to put them in the rail, and slowly squeeze the greased ball into the socket using a "G" clamp. I greased the rails and presto the windows worked like new!
I had to repair the arms on the drivers side, as the arms fell apart at the pivot point, by drilling a small hole and placing a large washer on one side then bolting it up, using a wheelnut spring washer to keep the tension on the washer.
Posted on Aug 01, 2012
My sony tv wega went off i cant turn it back on and the stand by button keeps flashing
Hi.
Sounds like there is a problem with the start up triac which is basically an electronic switch inside the unit.
could also be a reset problem or dry solder joint.
I have come across this problem whilst repairing these in the past, They are superb tv's and worth repairing. Check out the triac first and if you need further assistance don't hesitate to give me a shout.
Barry
Mar 06, 2015 | Sony Televison & Video
I recently purchased a Leister Hot-Jet S heat welding tool from a pawnshop and need the operating instructions for it.
Fireweedflo - you can find Leister's HotJet S operating instructions on www.LeisterUSA.com. This link will take you to the HotJet S page, where you can download the operating instructions. The English version starts on page 7. If you're ever in need of service or repair support for your HotJet, check out www.IHShotair.com. It is one of four Leister US master distributors and a Leister certified service center.
Apr 26, 2011 | Ovens
Where is the Triac & what does it look like?
A triac is a bidirectional switching device which in older model microwave ovens is used to regulate the AC input power to the high voltage section to turn the cooking power off and on and to set the cooking power.
Depending on the model, they would most commonly be located on or near the control circuit board or on the chassis floor of the oven.
They may look like one of those in the attached photo.
If you have a Jenn-Air microwave, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 16, 2010 | Jenn-Air Microwave Ovens
My Braun Multimix 280 will only operate on highspeed now. Can this be fixed?
Yes. You can do two things. Replace the swith curcuit board or replace the triac/tyristor on the board itself. The last solution requires you to unsolder the triac and loosen it from the heatsink(110v veriosn only. 230v version has no heatsink) and test it with a multimeter to establish if it has failed. (Testing of tracs can be googled.) In eather case you will need to open the casing.
1. remove the base palte by lifting the end opposite to the electric cord.
2. Loosen the bottom power outled slider, without removing it fully
3. unclip the curved plastic retainer in the front and unscrew philips head screw.
4. Work around the edges of the two halves until it comes apart and you are able to free the slider from its return spring.
Replace the cicuit board completely if available. Or resolder a new triac observing the orietation of the pins and reattach to the heatsink by riveting/cliping on or whatever applies to you model. Using heat conductive silicon paste between triac and heatsink is a good idea if it is originally fitted (if white paste residues can be seen). The European 230 v version do not have a heat sink, due to the higher voltage and thus lower current opassing through. If the Euro version, simply replace the triac, trim the pins on the back of the board nad put back in place.
Triacs can be obtained from any electronic componets dealer, as long as you can supply the code stamped on it. The Euro version has code TIC226N, which you can find in any component or manufacturer cross refereanse table. TIC226N basically means a 8 amp triac. Triac is simplified just a sort of ac transistor. The US version I do not have the code for, but it must have a higher ampere rating, thus the heatsink
To replace;
Put all internal componets back in place in the right halve. Put the left halve on top and fit properly by gently pressing together. Fit the screw in the front and the retaining clip. Fit the sliding cover by cliping it back on, observing that the notch for the return spring will meet the spring pin on the right side for it to snap in place. The spring pin can be observed through the slots for the sliding cover. Then insert the base plate reversely of how you removed it.
The problems of these mixers, is that if overloaded the maximum current rating of the triac's may be exceeded. This will cause the triacs to short curcuit and therefore will give full power in any mode.
To avoid the problem, avoide heavy batters, heavy doughs and prolonged high load tasks. Otherwise a very handy smart little mixer that should last for years.
Jan 13, 2010 | Braun M880 MultiMix Hand Mixer
Need exploded pic of dryer and instruction on how to replace belt it is broken
Searspartsdirect.com has some excellent exploded view parts diagrams you can refer to. Two other sites you may also try are pcappliancerepair.com and appliancepartspros.com.
For dryer belt routing diagrams, refer to repairclinic.com. Click on the "Repair Help" link, followed by the "Dryer Belt Diagrams" link under the "Special Features" section.
If you need further assistance please let me know. I hope this helps you.
Dec 29, 2009 | Dryers
Belt diagrahm
Go to repairclinic.com and click on the "Repair Help" link. On the following page, locate the "Dryer Belt Diagrams" link under the Special Features section. Refer to diagrams H, B or K. If you need assistance in determining which diagram you need, post back with your model number and I can assist you better. I hope this helps you.
Jul 23, 2009 | Kenmore 73952 Gas Dryer
Need a diagram or exploded view of a 1996 honda
buy a hines auto repair book for your make and year, there about $25 and tell you almost everything you need to know about fixing your car. well worth the money.
Jul 16, 2009 | 1993 Honda Civic 4 Door
Need exploded view maytag mod. mat25csagw please
Go to appliancepartspros and type in the model number you provided. There are some excellent exploded view diagrams of every section of your washer along with parts listings and prices. I hope this is helpful to you. If you need further assistance, please let me know.
Mar 03, 2009 | Maytag Washing Machines
Dryer problem
I could be wrong, but I don't know of a dryer that DOESN'T use a belt to turn the drum. If the motor is turning on, and the drum is not spinning, more than likely your suspicions are correct and the belt is broken. You can find a replacement at searspartsdirect.com. Just type in the model number you have provided and look under the "Tumbler" heading for item number 5 (part #341241). The website also offers some helpful exploded view illustrations to assist in part location and installation.
Repairclinic.com carries the part at a cheaper price (item number 529597). Use the part number provided by the Sears website for your search criteria. Repairclinic also offers dryer belt installation diagrams. Just click on the "Repair Help" link at the top of the page and look under the "Special Features" section on the following page for "Dryer Belt Diagrams". Magic Chef uses diagram F. I hope you find this information helpful. Let me know if you have any questions.
Oct 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Feb 16, 2007 | Nokia 6230
Welding Tools Logo
185 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
