Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Will not stay running once started - Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
  • 437 Answers
Old gas, bad fuel lines; Carburetor needs rebuilding; fuel filter clogged.
These are a few of the things that could be wrong.
It sounds like not able to keep the flow of fuel going.
Check these things out. If it is a 2 cycle trimmer have a compression check done on the engine before you spend any money.
Posted on Sep 25, 2009
It will start with the turn of the key but will turn off immediatly. Then by flooding it with gas directly into mouth it will stay running,I can drive it all over but once I turn it off it will not stay...
Your description indicates that the fuel pump may be too weak to start the vehicle but has enough fuel pressure to maintain running once it is started.
Oct 06, 2010 | Saturn L-Series Cars & Trucks
How long should the truck run when started with the remotestarter
is this a factory remote or aftermarket, most all of them once started will stay running till turn off with remote, its de-activates once you turn key on
Feb 04, 2010 | 2007 Dodge Ram Truck
Jiffy ice auger its starts but doesnt stay running
Sounds like the float is stuck.See if you can remove the float bowl.Once it's off try and separate the float from the carburetor.The float will be holding in a small needle,check it for free movement.They're pretty inexpensive and would be a good thing to replace.The float will crack,then fill up with fluid.Once full it will cease to function,opening and closing off the fuel flow.Then the needle will stick and you'll get little or no fuel.It's a real simple carb,they're less than $50 brand new if it sounds like too much to work on.Hope this has been some help?You do know this is posted under PC Desktops,right?
Dec 17, 2009 | Computers & Internet
Car wont stay running after initial start up?
Will it stay running if you keep the pedal depressed. If so you have a Idle Air Control valve issue. If it wont run at all it may be a bad fuel pump
Jul 14, 2009 | 1991 Chrysler Imperial
Will the car stay running if the batterie is disconected
It should stay running. If your alternator is bad it may not stay running but in all cases it should stay running.
May 14, 2009 | 1999 Chevrolet Venture
Battery light on, takes forever to start then dies once started
if you can get the car started again and with someone helping you have them take the positive side of the battery cable off while it is running and if it dies then it is the alternator also check your drive belt and when was the last time it was changed because it could be slipping
Jan 05, 2009 | Lincoln Mark VIII Cars & Trucks
Won`t crank
check your fuel pressure and also check your plug gaps and make sure you have a stong spark, you say it stays running once started on ether? does it run well or poorly? is it drivable or not please explain in more detail -please rate -jeff
Aug 16, 2008 | 1994 Oldsmobile Achieva Special Edition
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
203 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
