Question about Canon PIXMA MP780 All-In-One InkJet Printer
Can't retrieve fax from memory
It keeps saying change paper to A4 ltr/legal plain
  • 619 Answers
SOURCE: canon pixma mp780 getting memory
Open printer properties click paper to use /paper size then okey
Posted on Jan 10, 2008
mahhek
  • 657 Answers
SOURCE: Canon pixma mp 780 message says:change paper to
Go to Printer and Faxes in Control Panel, Right click on the printer for which you want to change the settings. click properties, go to printing preferences there look for paper size and select A4 or letter/legal as per your choice
Posted on Oct 01, 2009
97F350diesel
  • 1326 Answers
SOURCE: Trying to receive a fax. Display says
You have to cancel the fax. If its saying that then the paper sent to you was a legal sixe 8.5x14 and needs that type paper to receive the fax. Some faxes have legal trays and A4 but most don't.
Posted on Dec 16, 2009
muntejaya
  • 10421 Answers
SOURCE: My Canon all in one MF6550 started displaying an
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay lqdptr
Posted on Feb 12, 2011
muntejaya
  • 10421 Answers
SOURCE: Canon ImageClass D680 "Incorrect Paper Size" error message
Jay kbxlz
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
I have a brother IntelliFAX 1270e Plain Paper Fax Phone & Copier machine. It keeps saying Out of Memory/Erase Message. I don't know how to do this please help!!
Just unplug the power cord for a few seconds, then plug in again. this will erase all fax memory except speed dial and phone book numbers,or you have here manual to download ( look at the end of the user manual,option how to retrieve a fax. there you have listed how to delete faxes in memory).
Hope it helps
Feb 11, 2011 | Brother IntelliFAX 1270E Plain Paper Fax
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
The alarm keeps flashing and the message says there is a paper jam. I cannot find a paper jam, but the fax cannot retrieve items in memory either.
Hi;
  1. Remove the cartridge look inside is there any paper rmove it carefully
  2. remove the paper from cassette
  3. load the paper again
Aug 10, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I have a canon 4350d printer when i give print it asking for current paper size in every print
you can define this size in it's driver property,,,,( settings--printer and faxes--canon--properties)
Apr 27, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Dec 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mp 780 message says:change paper to A4/letter/legal plain How do I do that??????
Oct 01, 2009 | Canon Office Equipment & Supplies
Setting paper size
Move up the plastic on the right side of the fax below the numbers, push Data Registration once below the number 21 then press Set on the front side of your Fax you w'll see on the screen of the fax USER SETTINGS press down arrows key below Space 4 times you w'll see then PRINTER SETTINGS then Set again you w'll see RX REDUCTION then down arrow key below Space on your right side of the fax press down 1 time you w'll see PAPER SIZE then Set again you w'll see LGL then press the down arrow key 3 times you w'll see LTR then Set again and whait 2 or 3 secons and you DONE
Apr 30, 2008 | Canon FaxPhone L75 Plain Paper Laser
Canon pixma mp780 getting memory
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
