Question about Fujitsu LifeBook S7020 Notebook
In the battery, number lock etc window when booting, the num lock, caps and Scr are flashing and the laptop will not bootup
burns-o
  • 114 Answers
SOURCE: startup problem
that wouldn't mean the processor is off, it means there is a problem with the motherboard. I don't know the exact problem with the motherboard. but it could be something wrong with the processor too. but I suggest you take your PC to like Circuit city, best buy, or your local computer shop to have them take a look at.
Posted on Jun 10, 2008
hothawk
  • 174 Answers
SOURCE: Laptop fails to boot up. Caps lock & Num lock
The problem may be your display LCD is not working - check that hard disk is running - when you touch you may feel a running sensation -
There are many problems It can be motherboard problem or any of the devices is not working ie.. hard disk PCMCIA Cards i suggest you should an expertize check.................
Posted on Jan 20, 2010
  • 109 Answers
SOURCE: Dell Vostro 1320 num lock flashing
it may be loose RAM take out your ram and put it back in making sure it is in tight.
Posted on Mar 14, 2010
colt_baldwin
  • 103 Answers
SOURCE: Blank screen on laptop
Sorry to hear you are having problems. I have had this same issue before with this particular model. The following solution works 90% of the time.Perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. Some HP Notebook PCs come with one stick of memory but have two memory slots. The problem could be that the stick of memory or one of the memory slots has a bad connection. The memory module compartment on most notebooks is located on the bottom of the case. The exact position varies by model. However, on some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
Use the following steps to remove and reseat the memory modules: Step 1 - Remove the electrical power To remove all power from the computer and prevent accidental damage to the electronic components, do the following:
  1. Turn off the computer by pressing and holding down the Power button for about 30 seconds.
  2. Unplug the AC adaptor from the notebook.
  3. Slide and hold the battery release latch to the unlock position.
  4. Use your finger to lift the battery up and out.
  • Remove the memory module cover on the bottom of the notebook .Loosen the compartment's retention screws and lift up and remove the memory compartment cover. Remove the memory modules from the memory slots To prevent damage to the memory module, grasp the memory module by the side edges. Do not touch the metal contacts.
    1 - Pull the retention clips away from sides of the memory module
    2 - Gently pull the module out of the memory module slot
  • Reseat the memory module by holding module at a 45-degree angle, and pressing it firmly into the memory slot until it is seated.
    After reseating the memory module, replace the cover over the memory compartment before restarting the computer
    Hope this helps FiYa! If you find this solution helpful, please take a moment to leave us some feedback.
    Thank You!
    Posted on May 12, 2010
    SOURCE: Dell Vostro 1510 laptop.NUM lock
    Go to dell site and check what LED flashing means.This points to the problem.good luck
    Posted on Apr 13, 2011
    What does it mean when your laptop's power lights flash ? Including the power button?
    "The following table illustrates the meaning of blink codes used on some notebooks with EFI environment.
    The blink or beep codes on your computer may have different meanings. When you contact HP for
    support, the agent needs to know the model of your computer and may ask you about blinking LEDs
    or beeping tones to help troubleshoot a startup problem.Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError Condition
    Continuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
    1time---Caps Lock/Num Lock-----CPU------------------CPU not functional
    2time---Caps Lock/Num Lock-----BIOS----------------BIOS corruption failure
    3time---Caps Lock/Num Lock-----Memory-------------Module error not functional
    4time---Caps Lock/Num Lock-----Graphics--------------Graphics controller not functional
    5time---Caps Lock/Num Lock-----System board----------General system board failure
    6time---Caps Lock/Num Lock-----BIOS-------------------BIOS authentication failure
    Continuous blinkAC power adapter LEDPower adapter Insufficient power"
    Nov 01, 2012 | Compaq Computers & Internet
    Tip
    Laptop LED Blink on Startup There are many reasons that a computer does not...
    There are many reasons that a computer does not startup or boot into the Windows operating system. If your computer will not start or boot, you will see or hear symptom to indicate the general area of the problem.
    Startup Symptom: LEDs blink but does not start
    The blinking LED lights on newer computers, or the beep tones on older computers, will help support agent determine what hardware component is not responding properly. The exact meaning of each code varies with the model, and the user cannot change any of the blink or beep codes.
    DO THESE FIRST - Perform a hard reset.
    If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
    2. Disconnect the AC power adapter, remove the battery and then press and hold the power button for at least 15 seconds.
    Identify the number of blinks or beeps
    When there is a start-up problem and you see LED lights on the keyboard blink a few times (between 1 and 8 blinks) do the following actions.
    Table of Sample Blink Codes
    The following table illustrates the meaning of blink codes used on some notebooks. The blink or beep codes on your computer may have different meanings.
    Meaning of Sample Blink Codes for some EFI Notebooks:
    1) Number of Blink: Continuous Glow, Blinking LED: Battery power LED, Component: Battery,
    Error Condition: The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
    2) Number of Blink: 1, Blinking LED: Caps Lock/Num Lock, Component: CPU,
    Error Condition: CPU not functional
    3) Number of Blink: 2, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
    Error Condition: BIOS corruption failure
    4) Number of Blink: 3, Blinking LED: Caps Lock/Num Lock, Component: Memory,
    Error Condition: Module error not functional
    5) Number of Blink: 4, Blinking LED: Caps Lock/Num Lock, Component: Graphics,
    Error Condition: Graphics controller not functional.
    6) Number of Blink: 5, Blinking LED: Caps Lock/Num Lock, Component: system board,
    Error Condition: General system board failure.
    7) Number of Blink: 6, Blinking LED: Caps Lock/Num Lock, Component: BIOS,
    Error Condition: BIOS authentication failure.
    8) Number of Blink: Continuous blink, Blinking LED: AC power adapter LED, Component: Power adapter,
    Error Condition: Insufficient power
    Common solutions for issues that cause blinking LEDs or beep tones
    When the computer can boot into the BIOS, run the memory test to identify other issues.
    Check for loose connections and test the memory
    Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a hardware component is loose because the computer was dropped or jarred. The problem could be that the stick of memory or one of the memory slots has a bad connection.
    Check for loose memory modules
    If a memory module is loose or is not making good contact with the memory slots, the computer does not recognize all of the memory. Reseating the memory module may resolve memory failure errors.
    on Mar 21, 2011 | Computers & Internet
    The capslock and the numlock leds r flashing continously. the screen is blank
    How many blinks between pauses if there are pauses? Look at this chart.
    Jun 30, 2011 | Compaq Presario Notebook
    Laptop wont boot up to anything, just a black screen when you turn it on and the light at the cap locks flashes 5 times and thats all.
    Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError ConditionContinuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.1Caps Lock/Num LockCPUCPU not functional2Caps Lock/Num LockBIOSBIOS corruption failure3Caps Lock/Num LockMemoryModule error not functional4Caps Lock/Num LockGraphicsGraphics controller not functional5Caps Lock/Num LockSystem boardGeneral system board failure6Caps Lock/Num LockBIOSBIOS authentication failureContinuous blinkAC power adapter LEDPower adapterInsufficient power
    Oct 10, 2010 | HP Compaq 6735s Notebook
    Compaq 6735s notebook pc goes to HP screen, but wont boot
    First you need to determine how many blinks you are getting when you try to power on the laptop.
    Check the blinking codes below and reason behind that for HP Compaq laptops
    Blinking battery power LED Battery Insufficient charge on the battery
    Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
    Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
    Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
    Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
    Blink: 5 - Caps Lock/Num Lock - System board General system board failure
    Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
    Plz get back so I can suggest you the steps to resolve the issue.
    Dreamkam
    May 24, 2010 | HP Compaq 6735s Notebook
    Hey. i have a compaq CQ61 notebook and am having troubles turning it on. Whilst using it casually e.g. the internet and powerpoint it just shut off. When plugged in to the power supply, the light glows on...
    First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
    May 24, 2010 | Compaq Presario Notebook
    My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
    Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
    Component
    Error Condition
    Battery
    CPU
    CPU not functional
    BIOS
    Memory
    Graphics
    System board
    BIOS
    Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
    Keypad numbers are locked on, how do i unlock??
    Boot to your Bios and look in advanced for num lock and disable.
    or
    go to run in the start menu.
    typ: regedit.
    Go to: HKEY_USERS\.Default\Control Panel\Keyboard
    Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
    Explaination numbers.
    0= Truns Off, Num Lock, Caps Lock, Scroll Lock
    1= Turns On Caps Lock,
    2= Turns ON Num Lock,
    3= Turns On Caps Lock, and Num Lock
    4= Turns ON Scroll Lock
    5= Turns on Caps Lock, and Scroll Lock
    6= Turns On Num Lock, and Scroll Lock
    7= Turns On Caps Lock, Num Lock, and Scroll Lock
    Hope this helps.
    Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
    HP DV6110us: 4 beeps, no boot
    besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
    HP DV6000 LED Blink Codes
    LED Component Error Condition
    Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
    Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
    Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
    Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
    Blink: 5 - Caps Lock/Num Lock System board General system board failure
    Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
    Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
    Won't boot
    was there any changes done to your system like upgrading anything
    All your power seems to be on right
    Dec 13, 2008 | Dell Inspiron 1525 Laptop Jet Black
    Fujitsu LifeBook S7020 Notebook Logo
    78 people viewed this question
    Top Fujitsu Computers & Internet Experts
    Computer Links
    Tony
    Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
