Question about MSI KM2M Combo-L (MS-6738-010) Motherboard
Battery Stuck Prasario V6000
I have a new larger than origional HP Battery and its stuck.
I need help as when this computer locks up I have to remove the battery to solve tha problem and am operateing on Borrowed time.
Sam I am
  • 44 Answers
Use a small flat headed screw driver and force the little ****** out, be careful not the hit the mother board, they don't like that
Posted on Sep 27, 2009
Battery dead , key stuck in ignition can't open doors or hatch to get to battery in trunk 2006 HHR
remove the rear seat ; if needed; crawl to the back of the hatch and release the hatch lock from inside using a blade screwdriver or, have a locksmith at the dealer make a new key by code using your vin number
Feb 18, 2013 | 2008 Ford Taurus X
HP pavilion g4-1015dx battery issues
Bring it down to the computer repair store and have them remove it on the spot, or good handyman that that knows what he is doing.
Apr 23, 2012 | HP Computers & Internet
Stuck on installing updates
DO THIS FIRST - Perform a hard resetIf a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
Feb 18, 2012 | HP Mini 1000 Netbook
Battery release latch locked in open -hp pavilion dv4 1313dx
The same thing happened to my HP laptop. The sliding lock mechanism relies on three little hooks to hold the battery in place. What had happened to mine was that one of the hooks (the one nearest to the switch) had gotten stuck (this is quite difficult to explain, but just examine the three little hooks closely and you'll notice it the difference.) I freed it simply by pushing it with my thumb to unsnag it. The battery is now securely back in place, where it will stay!
Jan 13, 2010 | Computers & Internet
HP Pavilion dv6225us laptop battery release latch
is the latched stuck in the open or closed position? if it is in the open position you may be able to wedge a pick or small flathead and gently ease it out. if it is in the locked position attempt to use one of these same tools to move the latch to the open position. hope this was helpful.
Dec 09, 2009 | HP Computers & Internet
How di i get back to the origional facebook on my
after loging in at address bar type
www.facebook.com
it will bring you back to the original
Nov 03, 2009 | Computers & Internet
Hp laptop presario V6000 can't startup. Black Screen.
its a common problem with these models.
try and keep away from hp
Jul 24, 2009 | HP Pavilion dv6000z Notebook
New pocket media drive is stuck in computer
Just a dumb answer try removing the screws, if it doesn't work use your strength and rip it out. If you can't, then open the computer and take out the bay, then rip it out. If you still can't, step aside and let a mad do it for you.
Jun 05, 2009 | HP Computers & Internet
HP Pavillion dv6700 won't load up - gets stuck on logo page
i afraid that cause by hardware, but try to remove battery and only use the power. or press F2. if prsseing f2 the new screen(bios) open try restart and press F8. tell me is it work or not
Jan 28, 2009 | HP Pavilion DV5234US Notebook Laptop
I have a mini Maglite with one battery stuck in the barrell
I had a similar problem. My wife put two AA rechargeable batteries into her mini maglite. Apparently the AA rechargeables have a slightly larger diameter than alkaline batteries. One of them was stuck in the barrel. I was able to remove it by first removing the lens and bulb so as not to break it. Then I slammed slamming the barrel down hard onto the carpet on our floor. This hard shock jarred the battery loose and it came out of the barrel. Hope this helps someone out.
Jan 15, 2009 | MagLite Mag-Lite& Flashlight
MSI KM2M Combo-L (MS-6738-010) Motherboard Logo
117 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
