Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
When i print pictures it comes out with horizonal lines going through?
Horizonal line across middle of screen top half of picture perfect bottom half has small lines in picture hitachi hd S 69 plasma
I'm not sure if this model is the one that has resistors that go bad. You can actually purchase a pack of resistors in a kit. It will come with solder, the resistors and instructions. You can lay the tv out and take the circuit board out to find the blown components, and replace the bad ones. Takes about an hour start to finish and will cost around $65.00. It has been a few years since I did this, so I'm not sure on the price.
Apr 04, 2015 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Pictures have horizonal lines
it seems the problem with your lens !
Nov 23, 2012 | Samsung DualView TL205 Digital Camera
Printer gives warning that toner life is gone. I replace the toner twice . Each time it prints one page and then gives error message. Page that did print out has dark horizonal lines.
Check the toner cartridge, side gears, you can see a reset lever (that lever is very important) show in the next picture.(cartridge new)
Jun 28, 2011 | Brother MFC 7840W Printer
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
On my HD1080 Mitsubishi projection flat screen the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center. If I...
You have poor contacts and or dry joints. Resoldering on the convergeance panel and powersupply/line timebase board will probably fix it.
It should take less than an hour in labour terms.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Pictures come up with horizontal lines in them.
What color are the horizonal lines ??
Try changing the toner and cleaning the rollers.
Jul 28, 2009 | OKI C5500n Printer
Horizonal line
I think you have a fault on the picture frame board. If you can check for this yourself or find a competant technician. Hope this helps.
Apr 02, 2008 | RCA F32650 32" TV
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
Toshiba Television
it could be a loose or bad solder joint
Oct 31, 2007 | Televison & Video
Problems with taking pictures of horizons and buildings
This Nikon's expertise to fix - contact customer support- they may repair or offer a replacement.
Jun 04, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
