Question about LG Xenon GR500 Cell Phone
I have a text messaging icon on the upper part of my screen that wont go away. I do not have any new messages, but the phone keeps telling me that I do
How to block text messages
You can block text messages from a specific number or contact on your Android device with a third-party solution. Just follow these steps.
Blocking Text Messages
Option 1
Note: These steps are for the stock “Messaging” app included with Android 5. Some carriers may include a different app for messaging.
Open “Messaging“.
Press the “Menu” Menu icon icon located at the upper-right corner.
Select “Blacklist“.
Set “Blacklist” to “On“, then select the plus (+) to add a person to block.
Type the number you wsih to block. Check “Block incoming calls” and/or “Block incoming messages” as desired, then select “OK“.
If you wish to remove a number from Blacklist, select the number, then choose “Delete“.
Option 2
If your messaging app does not offer a Blacklist option, use Handcent.
Download and install Handcent SMS for your text messaging needs. It’s available in the Google Play store.
Since you’ll be using Handcent for text messaging, disable the notifications for your current text messaging app. Otherwise, you’ll get double notifications for text messages.
Open Handcent then select the “Menu” Android menu button icon at the upper left corner of the screen, then select the gear in the lower left corner of the screen.
Select “Security & privacy” > “Manage blacklist“.
Tap the plus (+) icon to add the phone number you wish to block. You can choose one from your contacts, call logs, or input the number directly.
Now all of the text messages from that person will be blocked and not visible in the Handcent app. You won’t get notifications you’ve received a message from the person either. If you ever want to unblock the person, return to the “Manage blacklist” screen, tap it, then select “Unblacklist“.
Some users have reported that the app “Private Space” works well for them.
Sending an Automatic Reply
If you want to let a person know they have been blocked, you will need to download and install SwiftReply. SwiftReply will allow you to setup an auto reply for specific Contacts.
Ensure the mobile number you wish to block is listed in your Contacts.
Open “SwiftReply” and tap the plus icon (+) to make a new auto-reply.
Type the name you would like to use for the reply and the text you would like to send to the person.
Scroll down and select “Enable User Filter” > “Contacts“.
Tap “Add” and choose the people in your Contacts list that you would like to receive the reply. Tap “Done” when your list is complete.
Tap “Save“, then tap “Off” to turn the auto-reply on.
The specified people will now receive your message automatically and Handcent will block them from your view.
Feb 04, 2016 | Cell Phones
Flashing Text Message Sign- Not New Msg
it means your inbox is full.. in most cases anyway or that your phone is stuck on the text message icon.. it will go away afterawhile i had the same problem with my lg
Sep 04, 2009 | LG Neon GT365 Cell Phone
How to text
to text:
1. at the "home" screen, click the button to the left of the analoge stick, this should click on menu taking you to a screen with 9 icons.
2. click the icon on the top row in the middle called "messaging"
3. Select option one "new message"
4. Type whatever the message is using the numbered buttons 0-9.
5. Once finished, select the option "send to", and input the name or number you want to send it too.
6. To make sure it sent, go back to the options screen with "new message" but scroll down to the "sent" box, if the message sent than it would be in there, if not, your message will be in the outbox and it means you have a bad signal. If its in the "outbox" than hit resend and wait to see if it sends.
7. that's the basics of just sending "text" but "pictures" are different,
8. ENJOY!
Mar 29, 2009 | LG Shine CU720 Cellular Phone
Removing/clearing message icon on my rumor!
In "Messaging" go into Voice Mail (number 1) and select Clear Icon (Number 3).
Go into Settings/Tools- Settings (#1)- Messaging (#5)-Notification (#1)- Change this To Icon only.
Still in Messaging, select Message Reminder (#5) and change it so it doesnt keep sending reminders.
If its telling you you have a text just go in each inbox and selcet Delete all... see if that helps.
Feb 25, 2009 | LG RUMOR Cellular Phone
Motorola RAZR mieterious message icon
Check and see if someone has sent you a picture message that you haven't downloaded yet. If you have one, it will tell you that you haven't opened it, and all you need to do is download it if you want that to stop. Or you could just delete the message.
It's not a big problem that will mess up your phone, it's just telling you something. (:
Jun 21, 2008 | Motorola Mobility RAZR V3
Text Messaging
First try to clear your un needed texts, then check your multimedia messages.
Mar 07, 2008 | Motorola Mobility RAZR V3
Voice mail
If you do not exit voicemail with *, you will get a text message with a couple of symbols. In that case, go to text message menu & delete that message--the icon on the main screen will disappear!
Dec 10, 2007 | Motorola Mobility MOTORAZR2 V9 Cellular...
Text message icon won't turn off
It is probabily because u have unread or old Messages stored in the SIM card.
Aug 04, 2007 | Samsung SGH-x426
Text Messaging
m8 i had a simmiler problem i had a fone witch would allow you to text but would only let me use 30 carectors before it went on to second messsage the result was i was paying 50p for a text message with 150 carrectors. i sent my fone to these guys they reprogramed it now its finehttp://www.mobilephoneservicecentre.co.uk/
Jun 20, 2007 | Samsung SGH-t329 Cellular Phone
LG Xenon GR500 Cell Phone Logo
80 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
