Question about Garden
What is the spark plug size and gap? ryobi weedeater 700r
  • 496 Answers
The "Champion" spark plug for your item is #RDJ7Y
Or another brand, "NGK" #BPMR6F/130-769
You can set the gap to .020"
Hope this helps...
Posted on Sep 25, 2009
What is the spark plug gap for the ryobi 320vbr blower
Hi and welcome to FixYa, I am Kelly.
The spark Plug Gap is 0.030. Any original or aftermarket spark plug for this unit is pre-set to 0.030. Unless you dropped the replacement plug it should be fine. All Ryobi engines 2 and 4 cycle have a 0.030 spark plug gap.
Thanks for choosing FixYa,
Kelly
May 07, 2011 | Garden
My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
Nov 27, 2010 | Ryobi Garden
Bought new e3 plugs for weedeaters and cant find gaps for them i have a Featherlite 20cc Fl20 and a Ryobi 31cc 700R
The gap for the Weed Eater 20cc engine can be set @ .025". The larger engine Ryobi 31cc/32cc class can be set @ .030" Either engine would operate within that .005" range and I know a 32cc Poulan calls for a .030" gap.
Jul 09, 2010 | Garden
Ryobi 700r trimmer does not start. Changed spark
hve you checked the HT lead and the on/off switch i had the same model as this and i changed everthing but in the end t chucked the thing away and got a sthil modle
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Not getting spark because i loosened the adgustment screws
GAP ON THE COIL ? USE A MATCH BOOK COVER. SPARK PLUG FOLD THE MATCH BOOK
May 25, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Spark plug wire on Ryobi 700r broke. How to
Spark plug wire on Ryobi weed Eater broke off. How do you fix it? Thanks
Sep 30, 2009 | Garden
Ryobi ss30 weedeater,if weedeater is flooded
If the spark plug is very wet, place the base of the plug against a metal part of the motor, with the sparkplug wire attached to the plug, and pull the starter rope, looking to make sure that the plug has a spark. If it doesn't, that is the problem and it may be that the breaker point gap has to be adjusted or the capacitor (condenser) has gone bad. It is not easy for folks with the typical tools of a homeowner to fix either of these problems, but it can be done. If the spark is good, pull the starter about ten times with the plug out to clear out the excess gas, dry out the plug and put it back in, then try to start it. Too much gas on the plug could indicate that you are pressing the primer bulb too many times or that the fuel adjustment is set too rich.
Jul 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I lost my owners manual for my ryobi 700r weedeater. serial number-105123136
I would go to www.managemyhome.com and type in the model # and it will display the manual which you can download to your computer.
May 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
958 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
