Question about Garmin GPSMAP 60CSx GPS Receiver
Freezing and shutting down
I have just upgraded the firmwar and the set wont start shuts off after 2 sec and also is hanging
Toshiba Tecra M10 hanging when windows is shutting down after an update
Are you sure you are not too fast or impatient for it. Sometimes after doing updates it might take awhile to get past the Windows is shutting down...
Give it some time and see what happens. If after 15 minutes it is still there, press and hold the Power Button until it shuts off then Reboot. Try shutting down again and see if it hangs.
May 14, 2012 | Computers & Internet
Sir i am having samsung s8003 jet from last 6 months... i have a serious problem with it.. First o*** my cell became dead suddenly . After that i gave it to service provider and he gave me a new...
did u ever had to turn the power on again of this phone? I mean does it also shuts off completely by itself ?
If it does , I would recommend u to get a new battery in see what happens?
Since u have a new updated firmware in it, I will still recommend u to give this phone a hard reset couple of time and also try to restore factory settings again.
Hope this helps.
thanks
Jul 01, 2010 | Samsung Jet S8000 Cell Phone
It keeps freezing up? Please hel! Thank you.
bro,
Have u tried upgrading this firmware...
Sep 02, 2009 | Audio Players & Recorders
N73 shut down when i upgrade the software and wont re-start
DEAR UR PHONE SWITCHED OFF WHILE UPGRADING FIRMWARE.NOW UR PHONE IS NOT STARTING BECAUSE ITS DEAD,NOW TRY TO FLASH IT BY UFS OR TRY IT IN NOKIA CARE
Jun 30, 2009 | Nokia N73 Cellular Phone
Installed new update to fix freezing problem - created new one
I had the same problem. Mine originally stopped at 23/92 files. Then after a cool night, I started it again in the morning and got 91/92 files loaded before it started to fail again. I left the disk in and after about 20 fails in a row, it finally loaded!!! Recommend you just leave it in there and it should work. good luck
Mar 03, 2009 | Pioneer AVIC-Z2 Car DVD Player
Pausing or freezing during play
Either upgrade your system firmware and if that dosent work the sytem needs to be sent to sonty fo repair.
Jan 25, 2009 | Sony PlayStation Portable (PSP) Console
Ram upgrade problems IBM netvista 6794
You can try this site, it scans your system to see if your computer can run more memory than what is currently installed. it helps you find the right memory modules for your system and and an option for you to read reviews if available and if you want to buy it.
try this site: www.crucial.com
Please rate this solution
Dec 26, 2008 | IBM NetVista PC Desktop
My son's c250 shuts itself off after a minute.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Toyostove laser 55
sequence of operation is just like the monitor. combustion blower comes on to purge chamber of fumes. after the delay, the solenoid pump comes on and deposits fuel to the burner mat, within 20 sec the igniter comes on, incandesces and ignites the fuel if there is no flame, the flame rod is supposed to shut down heater and go into a lockout condition until shut off or unplugged to reset. check solenoid pump first. you already know the igniter works. check the fuel filter in the fuel sump might be clogged. check the fuel sump float valve, might be stuck, supposed to hang free in the sump with needle valve open. thermostat is digital just starts and shuts down the burner and solenoid pump.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater:...
Garmin GPSMAP 60CSx GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
