Question about Motorola Mobility Moto Q
Battery drains quickly. Loses charge when plugged
Battery drains quickly. Loses charge when plugged in overnight
  • 3 Answers
Sounds like you need a battery. The key here is that the battery is losing charge while it is supposed to be charging. Works like a car battery, even if the alternator is working 100%, if the battery is pooched, the car won't start.
Posted on Oct 01, 2009
Battery checked and holds its charge when earth lead and live lead connected the battery will go flat overnight
Something is being left on to drain a battery that quickly, or the system has a dead short in it somewhere. The only drain should come from the alarm system and chronometer in the radio to keep the time correct. That will only drain a battery in about 6 months of not being charged from engine running. I've found the easiest way to check if anything else is still draining power is at the fuse box. With switch off, test each fuse to see if there is still power on them. Then pull the fuse that is still powered and see what isn't working now and the grounded system will show itself. Just leave that fuse out overnight and see does the battery drain down. if not, go thru that system and find the short or faulty unit it's connected to. I always go directly to the grounds to fix problems if something isn't working, yet with your situation, the ground is causing the problem the other way. Something is still connected that shouldn't be.
Aug 17, 2017 | Cars & Trucks
Battery life draining overnight
Try disabling everything you can through the software, if not possible, unplug them. Then plug one in at a time and leave it overnight. If its OK in the morning, plug in the next item, and so on. Make sure battery is fully charged between each test. When the unit discharges overnight again, the last item you reconnected befroe it discharged is the one causing the voltage drain.
Aug 20, 2014 | Toshiba NB520 Netbook
Ipad battery wont hold a charge
Time to get a new battery.
Jul 15, 2014 | Cell Phones
Pc booting light blinking battery
As a rule this indicates a low battery or a failing battery. If you charge it and it drains quickly, it needs replacement. When getting a new battery (power cells), fully charge it overnight and use it until it drains completely. Once it is recharged for 24 hours, the batter will obtain a memory and last longer.
Jan 03, 2014 | Dell Latitude D620 Laptop (Latitude-C620)...
1999 Grand Cherokee loses battery charge overnight
have ur alternator checked. it will drain ur battery if it is bad.
Jan 05, 2013 | 1999 Jeep Grand Cherokee
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
My psp battery loses power "quickly" and charges very slow....
How old is your battery? You may want to think about buying a new one as it may be on it's way out. Even if it is fairly new you might have a lemon of a battery. It happens at times. IF your psp is new and your battery is doing this you should contact sony and see if they can replace your battery for free or a nominal charge.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Console
After fully charging my Motorola H700 all night, it loses its charge after an hour or two. When I plug it back in, the green light comes on in seconds. What's up with that?
seems some components inside your phone has shorted out. overnight charging is not recommended for it could cause overheating of the components of your phone which in time develops shorts.shorts , of course consumes rapidly the charge of the battery and it damages the battery also. have your phone diagnosed and fixed. next time if possible, remove the phone from the charger when it fully charged.
Nov 01, 2008 | Motorola Cell Phones
KU990 Viewty's battery loses charge very quickly
I saw on another forum two good tips.
1. Do not use a case with a magnetic clip.
2. Take off the battery cover and put tape over the two small etched squares that you can see one at each end on the inside of the cover.
I did this and up to now my battery has doubled its life. Still two bars after 1.5 days of medium use.
Terry
Mar 28, 2008 | LG KU990 Viewty
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
331 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
