Question about Lexmark X4270 All-In-One InkJet Printer
For some reason I can't receive faxes on my Lexmark X4270 through Vonage
  • 390 Answers
SOURCE: Lexmark X4270
Have you told your pc the fax equipment you want to use, and does it appear in the device managers list?
Posted on Feb 12, 2008
  • 390 Answers
SOURCE: error message 1203 on Lemark X4270
Does your unit have a printhead cleaning manager. Do this a few times. Check to see if you have to reset ink levels too.
Posted on Feb 14, 2008
  • 3940 Answers
SOURCE: lexmark x4270 copy and fax
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
reference: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS22014&relevance=1
Please rate this solution. =)
Posted on Jul 14, 2008
SOURCE: Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Posted on Aug 20, 2008
spiceprince
  • 31 Answers
SOURCE: LEXMARK PRINTER
change the dialing mode from tone to pulse
Posted on Jul 24, 2009
Hi, i have a cuestion and i hope you can help me i cant receive faxes in my Lexmary x4270 is connected to PAP2 and configured codecs etc, and this PAP2 is connected at the same time to PBX asterisk,what...
Here are some guidelines on how to receive faxes behind a PBX system:
  • First, make sure your Lexmark X4270 printer can receive faxes when not connected to PAP2 and the PBX system.
  • Ensure that your printer/fax is connected to correct Phone port on your PAP2.
  • Advise the sender to dial your number so that there is a pause before dialing the extension number to your fax machine. They could insert commas between your fax number and the extension number. It inserts a delay of few seconds each. (e.g. 1234567890,,,,,,,,,,456)
Aug 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do I set up my fax to my Lezmark X4270
Here's the link to download the Lexmark X4270 User's Guide. http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html. Scroll to Setting up the All-in-One for instructions on how setup the printer for faxing. Hope this helps.
May 27, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 will send fax but won't receive
Hello sir; The better solution is replace a phone cable.
Feb 01, 2010 | Lexmark X4270 All-In-One InkJet Printer
My Lexmark X4270 All in One will not fax, I have tried everything but it still won't work. I have Vonage as my Phone service and my computer runs through a Linksys router. Can anyone help me?
Faxing over VOIP is tricky and unreliable at best. Your phone system support people at Vonage should be contacted. This is not a problem with your Lexmark all-in-one product.
Jan 13, 2010 | Lexmark X4270 All-In-One InkJet Printer
I'm having trouble accepting faxes on my Lexmark
for most phone companies, you may send faxes from your home phone number but to recieve faxes you need to add another phone line, like a business or additional home line. hope this helps please rate me and thanks for choosing enterprise computing solutions.
Oct 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Trouble faxing and receiving fax from "Brother 575".Can you help me with my fax machine? I have vonage, and I still can't receive any faxes. The machine makes copies, and receives calls,send faxes, but not...
Try changing the "Bandwidth Saver" settings on your Vonage account from the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
Hopefully this will work for you.
Dave Grannas
Jun 01, 2008 | Brother FAX-575 Plain Paper Thermal
Fax problem
Check your preference settings and make sure the fax is set to receive faxes (my friends has 6 different settings) Your manual should tell you how to do this. The default is different for many fax machines.
Jan 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark
i am able to send out a fax on my lexmark x4270 all in one printer but when someone else sends me a fax i cannot receive it can
you give me a solution on this i need to be able to rec faxes
it is important in my work thank yoou
Oct 03, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
