Question about Brother IntelliFAX 1270E Plain Paper Fax
Receipt to confirm sent fax
I would like to be able to send a fax and then have my fax machine print a receipt saying that it sent the fax. I can't find an answer in the manual and our office recently moved, therefore the machine was unplugged. It was set up this way before, but it reverted to its old settings.
Logjam
  • 159 Answers
SOURCE: Receiving Faxes
You will have to ask yourself the question "What has changed?" If you changed nothing, then something else has that is beyond your control. Now, you have to decide whether you are using a single telephone line for faxes and telephone, or whether you have "distinctive ring" also called "smart ring" by some companies. It is not a smart thing to use both. You can print a list of settings to see what the machine is set to do. Now if you want to use distinctive ring, set the ring pattern to the one you have chosen with the tel company. If you have chosen a double ring, and you have set your panasonic telephone to receive on 4 rings, then it will count all the rings and pick up after only 2 sequences. To see if this is the problem just remove the telephone base station from the system and then try to receive a fax.
Posted on Jun 09, 2008
SOURCE: fax receipt from Canon Super G3 Fax-L220
Insert paper and press Stop.
Posted on Aug 15, 2008
SOURCE: Fax does not print a confirmation page.
Use Function 8 not 6 and use set to lock it in. Lawrence
Posted on Sep 04, 2008
leroyal
  • 2120 Answers
SOURCE: Fax will only send and not receive
Call your fax machine from a regular phone and listen for fax tones. Sender may be dialing the wrong number. Is your phone line DSL?
Posted on Sep 06, 2008
leroyal
  • 2120 Answers
SOURCE: Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
Posted on Sep 12, 2008
How to get a receipt for a sent fax?
Please follow the steps below:
  1. From the Home screen, navigate to Fax Setup. Touch the Setup button.
  2. Go to Fax Setup.
  3. Go to Reports.
  4. Select Print Confirmation Page or Print Activity Logs.
I hope this information has been helpful.
Sep 18, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
How do I set automatic fax receipt?
If you got a satisfactory solution to the fax receipt issue, I would surely appreciate your sharing it with me. I don't think that any HP all-in-ones will give you a receipt from the recipient. I need this too.
Maybe I will reinstall Win Fax
Jun 02, 2010 | HP LaserJet 3390 All-in-One Multifunction...
RECEIPT FOR SENT FAX
Pree menu/set then numbers 2, 4, 1. Chose on with the up and down arrows then press menu/set.
May 28, 2010 | Brother MFC 420CN All-In-One InkJet...
How do i print a report confirming the receipt of a sent fax
In the main menu under "fax" options you will find the option to print a fax report.
Nov 03, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Q. 1 - When I try to send a fax I get an error message that says: Fax Send Report is set to Off Q. 2 - I have an 1/2 inch black line down one side of any copy I try to make.
1. Usually a "fax send report" just means that you will not receive a "receipt" or "confirmation" that the fax was successfully sent. Changing the setting to off is pretty much just saving you ink & paper. When my fax machine report is set to off, I only receive a receipt if the fax was unsuccessful. However, all fax machines are different and have a mind of their own...so your best bet it to refer to the owner's manual or call the company where it came from.
2. The only thing I can think of is maybe you need to replace the plexi-glass on the copier or do an internal wipe of the underside of the glass. Sometimes the ink can smear from underneath when faxed papers get jammed or printed.
Sep 04, 2009 | HP Office Equipment & Supplies
Need printed confirmation fax receipts
I had the same problem with my 6210. A different machine, but this may be worth a try. You need to go to the general setup, rather than the fax menu on the keypad. Two pushes of the button takes you to "print reports". Press OK and you go to "Fax Report Setup", OK again gives you "Print Report". You then can toggle with the arrows for the various options. In this case press OK when you are on "sent faxes"
Apr 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Receipt for sent faxes
I called Sharp on a toll free number and got all the info I needed.Thank you!
Aug 05, 2008 | Sharp UX-P115 Plain Paper Thermal transfer...
Information about e-mail
You cannot know for sure.
If you don't get an automated "failure delivery" message from sending server like "destination unreachable", you can assume that the mail was sent.
The other aspect is -DO the recipient RECEIVED the mail?,
SENDING mail does not assures you that it was RECEIVED.
Well, There is a way to add a confirmation request to your mail but most people click "NO" to the request.
To configure the receipt request in outlook express do the following:
Open outlook express --> press on "tool" tag --> a new menu is displayed, --> press on "options" tag, a new menu is displayed, --> press on "receipts" tag and tag "V" at the first chioce "requesting read receipts".
To configure the receipt request in outlook (not express) do the following:
Open the outlook program and press on "tool" tag --> a new menu is displayed, press on the "options" tag, a new menu is displayed, press "preferences" tag -->press on "email options" tag --> press on "surveillance options button", a new menu is displayed, then tag(V) on the 6th tag "send receipt"
May 06, 2008 | Pitney Bowes 9920 Plain Paper Fax
FAX CONFIRMATION
-press menu
-press 3, then press 6 to select Print Report
Apr 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
Brother IntelliFAX 1270E Plain Paper Fax Logo
115 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
