Question about Toshiba DKT-2020 Corded Phone
We have a DKT3020 phone system. How do you set
We have a DKT3020 phone system. How do you set the date and time on the display?
  • 45 Answers
You can go to any display phone:
For the date
1. press intercom
2. dial #651
3. enter yymmdd example ~ 091005
4. press the # key.
5. hang up
For the time
1. press intercom
2. dial #652
3. enter HHMMSS example ~ 170800 in military time.
4. press the # key.
5. hang up
Posted on Oct 05, 2009
How do I turn off flashing message notification?
Try leaving the phone on the hook and entering Intercom #409. You may have to do this a few times if the "phantom messages" are stacked up.
Sep 17, 2014 | Toshiba DKT3020-SD Display Telephone
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
How do I change the Date and Time displayed?
You log into the Phone administrator settings, Go to General, Select Date and Time and correct them for the entire phone system.
To Log Into System Programming:
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
3. Press: NEXT Display will read: "B. General Admin"
4. Press Show
5. Select Date and Time and Press Show Correct Date and Time then press release. Let me know if you have any other questions.
May 16, 2011 | Meridian M9316 Corded Phone
Toshiba DKT2020SD Phone Change date/time
Changing time on Toshiba DKT3020-SD
Oct 01, 2010 | Toshiba Lands Phones
I need the directions to set the time and date on Partner 18D phones and how to set up extentions
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
To change the date enter #101
the display will say system date and the current programmed date
enter in the new date in MMDDYY format
press feature "00" to logout
As far as setting up the extensions, I'm going to need a little more specific info to help.
Aug 26, 2010 | Lucent PARTNER18 Corded Phone
HOW DO I SET THE TME AND DATE ON PHONE
enter in "#103"
enter the new time in 24 hour format to change the date enter #101 the display will say "system date" and the current data enter in the date in MMDDYY format
Aug 15, 2010 | AT&T Lucent MLS-12D Phone
On a Toshiba DKT3020-SD, how do I enter the User Programming Mode. I tried pressing #9876 but it did nothing.
There are two programming modes. One is User the other is system. for user programming press 3,6,9,hold at same time. For system type hold *#*#1*2*3* and enter password 0000
Feb 04, 2010 | Toshiba DKT3020SD Corded Phone
How do you change the time on the phones. Since Daylight Savings time My clock is off by an hour
How do I change the Time and Date on a Merlin Legend system?
To change either the Date or the Time on the Legend system, you must program it from the main System Programming console (MLX-20L). This will change the Time or Date on all the display phones throughout the system, except the ATL (Analog) display sets. These phones must be programmed on each individual set.
How to change the Date in the Legend system:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit.
  4. Press System.
  5. Press Date.
  6. Enter date in following format: mmddyy (where MM is the month, DD is the day, and YY is the year).
  7. Press Enter.
  8. Press Exit.
  9. Press Home to exit programming mode.
How to change the Time in the Legend system:
  1. Press Menu.
  3. Press Exit
  4. Press System.
  5. Press Time.
  6. Enter the time in military/24 hour format: HH:MM (where HH is the hour, 01-24, and MM is minutes, 00-60).
  7. Press Enter.
  8. Press Exit
Nov 04, 2009 | Lucent Merlin Legend MLX-20L Phone
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
Toshiba DKT-2020 Corded Phone Logo
572 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
