Samsung ML 2010 Laser Printer
Problem for Samsung ML 2010 Laser Printer
PAPER DOES NOT FEED THROUGH - TRIES TO PICK UP AND
By jmohr678 on Sep 25, 2009
PAPER DOES NOT FEED THROUGH - TRIES TO PICK UP AND WILL AFTER MANY ATTEMPTS - WHAT CAN I DO?
Best Solution
posted on Sep 26, 2009
Very Helpful)
simplifyITuk
Rank: Wiz
Rating: 98%, 7 votes
Sounds like the pickup roller is worn, you could try giving it a little more grip by giving it a clean or in more severe worn parts that are out of warranty i have used a fine sandpaper to rough the surface a little, just be sure not to leave any particulates on the roller. to remove the part simply locate the big dark rubber wheel at the back of the paper feed, with the front door down and the toner cartridge out, to my recollection the rubber part should be attached via a half moon shaped plastic insert that clips in at the top and hooks in at the bottom. so get your fingers behind the roller at the top and give it a pull and it should come away and then unhook, then give it a clean or find a better area of rubber on the item and swivel it round to that point, then hook it back to the bottom hooks on the bracket and push rearwards to clip it back onto the bracket at the top. hope that solves it, if not use some rubber bands around it to add a little more grip, shame to chuck these things away,
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung ML 2010 Laser Printer
Questions and Unsolved Problems for Samsung ML 2010 Laser Printer
Do you recommend Samsung ML 2010 Laser Printer?
Answer
Answer
necesito el samsung printer language para modificar un programa hecho en clipper 5.3 y correr bajo... (More)
Answer
Red light is glowing along with tonner saver light as soon as i switch on the printer
Answer
samsung 2010 installed new toner printing fades when printing documents
Answer
ml2510 red and green lites blinking alternately fast. cannot stop it. no print jobs in que. shut... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung ML 2010 Laser Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
