Question about Savin Office Equipment & Supplies
Can not connect my SAVIN 9925dp copier to a computer.
Does it have a special cable I need to buy.
  • 541 Answers
Depends. these machines did not come standard with print option. do you have that option? if so does it have a parrell or nic? the nic is the new stanard connection, ethernet j45 connector. are you printing mac? if so you have to have the post script ooption in addtion to the nic and print card.
Posted on Sep 26, 2009
Where do i buy a service manual for the savin 2406wd copier?
Try Katum.com. I think you will find there. They sell everything for copies.
See you!
May 05, 2011 | Savin Office Equipment & Supplies
Codigosc542 savin 9925dp
first you go to SP mode and switch OFF and ON if still problem exists change the thermisters -thanks
Nov 29, 2010 | Savin Office Equipment & Supplies
I have a Savin 8045e connected with USB and can't scan
its needs to be connected via network to scan and not usb i believe
Apr 12, 2010 | Savin 8035e Copier
Functional error SC542
This is a fuser temperature heating error.
the fuser has not heated up within 5 minutes after switching the copier on.
Most likely cause:
Heater lamp blown
Thermal fuse blown
Faulty power supply
Bad connection to fuser unit
You will need a service technician to fix this.
Dec 07, 2009 | Savin Office Equipment & Supplies
Trouble mapping Savin to network folder on computer
you will need to have the folder shared on the desktop. you will need user name and password. go to user tools. system settings. administrator. address book. create new user. in new user program, go to folder. enter computer name. browse network. you then enter user name and password for pc. should be done
Oct 21, 2009 | Savin Office Equipment & Supplies
Savin 9925DP multifunction unit. Printer does not initialize. Is there a way to reboot to factory settings? Thanks
IF YOU GO INTO THE SP MODE VIA CLEAR ALL THEN 107 AND HOLD THE STOP BUTTON TEH SCREEN SHOULD CHANGE GO INTO THE PRINTER SP AND YOU CN INITIALIZE FROM THERE // YOU WILL HAVE TO RE-ENTER YOUR IP AND NETWORK CONFIG AGAIN AFTER.. YOU CAN ALSO TRY TAKING THE NETWORK CARD OUT START COPIER WITHOUT AND THEN REINSTALL.. IF YOU TSKE THE SD CARD AND MEMORY OUT AND TRY A REBOOT THEN PUT THEM BACK IN THIS MIGHT ALSO HELP RESET YOU WILL GET ERRORS BUT YOU CAN RESET THESE AFTER.. GOOD LUCK IF YOU NEED MORE INFO LET ME KNOW
Jul 02, 2009 | Savin Office Equipment & Supplies
Cable
Standard Interfaces of the printer are:
USB 2.0, and 10/100 BaseTX Ethernet.
You can buy an ethernet cable to connect the printer on a network or a USB cable to connect the printer directly to your PC.
Good luck and please rate me, thanks.
Jan 05, 2009 | Savin 9935DP Laser Printer
Printer installation
try visiting www.ricoh.com for the driver info
Jun 13, 2008 | Office Equipment & Supplies
Connection to new computer
About conversion cables, u cannot guarantee the outcome specially with these type of printers.
My experience with POS printers, they like straight cable (Parallel on both ends) or (USB on both ends) and direct to computer connection.
Some successfully managed to get it working, mileage varies.
You can buy these type of cables from stores.
May 16, 2008 | Epson TM-T88III Thermal Printer
117 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
