Question about Take 2 Interactive Hidden & Dangerous 2 for Windows
After installing the game,it says bad drive - Take 2 Interactive Hidden & Dangerous 2 for Windows
How can i install the game Rage on my PS3 slim?
It appears that you have a bad spot on your hard drive. And may need to be replaced. Sometimes shutting down improper will defect it. Static electricity will do the same thing. Format the harddrive and start over if format dose not work replace the hard drive.Have a professional do it the hard drives are delicate an can damage easily.
May 05, 2014 | Sony Playstation 3 (PS3) Console
Game freezes up on 360xbox
If your game is freezing, it is most likely due to your game being scratched or otherwise damaged. Sometimes, a game can become damaged without you even realizing it. There are two ways to fix this.
1) (Obviously) Buy a new game.
If you don't want to go through the hassle, and would rather just get a fresh copy, go do it. Also, if your hard drive is relatively small or nearly full, I would recommend this.
2) Install the game to your hard drive.
The Xbox 360 has a feature that allows you to install a game to your hard drive. By doing this, the Xbox will run everything from your hard drive, which will make a scratched game no problem. You still need to have the game in the Xbox for it to start, however (anti-piracy measure). Installing is easy. Go to the dashboard, and scroll to where you would normally start the game from. But instead of pressing A to play the game, press Y on it and you should have the option to install it.
Note 1: If you can't install the game fully because it is so badly damaged, borrowing a friends or renting a copy and installing that one will work fine also. As long as you can start the game, you will be fine and freeze-ups will go away.
Note 2: If you have installed the game and it's still freezing, the problem is your hard drive. Some hard drives don't play well with some games, for an odd reason. To test this, try saving and loading the game from a USB flash drive. If it doesn't freeze, just continue to play on the flash drive. You can transfer all of data for the game onto your flash drive from the memory options in system settings.
Apr 09, 2011 | Microsoft Xbox 360 Console
Game is stuck is ps3
The most common reason for the game not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Have a nice day.
Aug 21, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 not loading games only.
The most common reason for the games not reading discs is a bad drive. The following website sells the drives and does installs:
Take care.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
My ps3 not reading a discs need the answer plaeas
Aug 20, 2010 | Video Game Consoles & Games
When I install a movie or game, message states need to install disc or no disc recognized
likely your drive cable is bad or the drive is bad. restart your machine and load bios and see if its shows up in your bios.fi it does your drive is working. and it could be the disc.
Mar 23, 2010 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
System boots up, but will not load games or movies
I think the laser in the drive maybe bad. Take a can of air and blow it into the dvd drive. This will make sure dust or dirt isn't on the laser.
Then at that point try different cd's, games and dvd's and if nothing will play then at that point the laser is bad or you can replace the whole drive you can find a laser or a drive fairly cheap on ebay.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
I have a specific game that will not play on my xbox 360,Lego star wars the complete saga. Every other game works but this one. I thought was a bad disc but i got it exchanged and still the same thing...
Try to install the game to the HDD. You must have the NXE Dashboard.
To do this simply insert the game onto the drive and go to the menu where it shows the game disc.
Press Y on the image of the game and select "Install to Hard Drive".
After the game finishes install select "Play From Hard Drive"
If the game fails to install try cleaning the disc with warm water NOT hot or cold water but WARM. After that dry the disc with a soft towel or some sort of SOFT cloth by wiping away from the center of the disc.
Jun 16, 2009 | Microsoft Xbox 360 Console
I cannot get Command & Conquer Tiberium Wars to install.
This is a general error which arises with corrupted files.First Make a "Checkdisk" test and make sure that your D drive is fine with out any bad sectors.If everything is fine,then probably that particular file is corrupted.Assuming you have reinstalled the game,the file may be corrupted in the dvd itself.Check if the game is working on othe systems.Also first copy the game contents to your hard drive and try installing the game from there. Install the game in a different directory [drive].
Nov 17, 2008 | EA - Electronic Arts Command & Conquer 3:...
Open Questions:
See all Take 2 Interactive Hidden & Dangerous 2 for Questions
Take 2 Interactive Hidden & Dangerous 2 for Windows Logo
23 people viewed this question
Top Take 2 Interactive Video Game Consoles & Games Experts
shaun
shaun
Bill Boyd
Technical Bulls
Technical Bulls
Are you a Take 2 Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
