Question about Garden
Small engines my lawn tractor with a 12 HP Kohler engine just started to stall out after about 20 minutes of running. I changed the fuel pump, filter, checked lines etc. Now it will not run unless the choke is on full. If you try to reduce the choke even a bit it stalls out.
  • 472 Answers
YOU NEED A CARB KIT IN THE CARB IT NEEDS TO BE CLEAND OUT
Posted on Oct 02, 2009
Sitting aout 7 yrs , will run with starter fluid and gas in carb until used then stops
Hi Gene, Seems like you need to pull your carby off and unscrew the bottom half from the top, 1st sign of a needle stuck inside the seat is a dry carby There you'll find the float, push the float up and down and see if the needle above the float slides up and down from the seat, If the needle stays up then it's stuck and NOT letting the fuel into the carby, Just pull it down with your fingers to loosen it up..I hope this helps.... CHEERS..
Apr 25, 2016 | Garden
Kohler 20 HP engine
air filter might be too dirty.. causes the air to **** too much fuel. almost like Choking the carb.
Sep 08, 2012 | Garden
Kohler engine stalling after a few minutes
Have you checked the fuel filter, lines, and look in the tank for any clogs at the outlet.
Oct 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Describe your 20 Hp 42"
The float an needle are stuck open causing the fuel to drain from the tank or be pumped by the fuel pump into the carburetor bowl, filling it and flooding the engine and filling up the air cleaner. You may even find that it has gone into the crank case sump contaminating the oil. Do not run until you have repaired the carburetor and changed the oil and if air filter got contaminated, that changed too.
I hope this is helpful for you.
Aug 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman Kohler 15HP 42
it deffenetly sounds like the coil is bad . as the motor increases in temp. the coil pack expands thus loosing positive charge. change it if it has points filr them a little too remove the tartar you should have a sharp blue spark
Apr 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftmen tractor w/ Kohler engine stalls out continually
Sounds too lean.
Can you cover the air intake with your hand 90% or use the choke a bit and then load the engine to see if it runs better?
If you ever find a carb with manual high and low mixture adjustments that will fit yours......put it on and keep it on.
You can usually get then from older tractors.
Aug 25, 2009 | Craftsman Garden
My Sears Craftsman Garden Tractor 22HP, dies after it gets hot
Sue your brother is right! I had the same problem and it turned out to be the gas cap. the small breather hole on the top was plugged with dirt. once I cleaned it out I took the rubber gasket out from the bottom of the cap and cleaned that as well. runs great now.
Jul 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
YS 4500 Stalls out after running for 20 mins
I do believe they change plug(s) and air filter? There could be impurities and water in tank. Check for any loose electrical connections. Problem with valve clearance. Keep me informed.
Jun 13, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
343 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
