Question about Magic Chef Refrigerators
Water seeps out of freezer side of fridg onto the floor, I have totally remover the water line going to the ice maker and it still has water seeping out. It builds up Ice on the bottom of the freezer and appears to slowly thaw out and seep out the front door. ?????
    President:
  • 744 Answers
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Sep 25, 2009
Testimonial: "You hit the nail on the head. I got your solution and went home and worked it right out. Seems to be working right now."
Our Jenn-Air JCM22 side by side refrigerator water dispensor allows water condensation to run out from behind the rubber boot that houses the on/off water dispensing press switch. In humid conditions this...
HI,OPEN THE FREEZER COMPARTMENT CHECK IF THE DISP ICE DOOR IS CLOSIN PROPERLY ALSO CHEK THE ICE MAKER FOR WATER LEAK,IF HOT AIR IS FILTERING THRU THE DISPENCER ICE DOOR WILL MAKING THE ICE BUCKET ICE TO MELT AND LEAK WATER,IF YOUR ICE MAKER IS BAD WILL LEAK WATER, IF YOU CAN'T FIND THE PROBLEM GET EXPERIANCES SERV TECH TO DIANOST THE PEOBLEM..
Feb 21, 2011 | Jenn-Air Refrigerators
Water line in freezer to ice maker is frozen
You have a " seeping " water valve ( leaking internally ) . Pull the refrig out and remove the line AT THE VALVE to the ice maker . Use a hair dryer inside on the frozen line , until you can blow thru the removed line from the valve . Then , replace the water valve .
Sep 25, 2010 | Hotpoint FFA80 Bottom Freezer Refrigerator
Its a side by side Siemens KA62DP90 GB freezer/fridge.it is new, i just turned on the fridge yesterday and also the icemaker and found my whole freezer frozen the next morning with water seeping out.
This may be due to any small leaks in the water supply line going to the ice maker. The leak caused water to flow outside and a part of it was frozen by the freezer. That is what happened. It is having only a simple repair to replace the pipe. But since this one is new, you may be well inside the warranty period. So don't take any risk. Just contact your dealer. Else it may spoil your warranty agreement.
Apr 22, 2010 | Siemens KI20R440 Refrigerator
The line to our ice maker is frozen solid with ice. Do you know how to get the ice out of it? I'd prefer to not have to defrost the whole thing.
Pull the refrig out from the wall and you will see where the single tube to the ice maker goes . Try removing the line housing straight out the back , and thawing at the sink . Or , 2 screws hold the ice maker on . Remove the ice maker and thaw the line with a hair dryer . You will need to replace the water valve ( the piece the wall water line connects to on the refrig ) due to a seeping problem . When the valve does not close completely , drops will seep into the fill tube and freeze , thereby , blocking the normal rate of water , entering the ice maker .
Nov 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker doesn't work
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the water inlet valve ( the piece that the wall water line connects to on the fridge ) . Also check to be sure that the fill tube from the back of the freezer to the ice maker , isn't blocked with ice , as this is caused by a seeping bad water valve . If the ice maker doesn't dump the cubes , after freezing , then replace the ice maker . Also check to make sure the coils under the front of the refrig , are clean of dust , lint , pet hair , etc.
Sep 16, 2009 | Refrigerators
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Water seeping around fitting on back where water line fastens tp
Where does the water seep from?
The compression fitting you speak of is for the ice maker and through door water (if you have it.).
If water is on the floor, then chances are the drain pan underneath the unit has a hole in it, or for some reason, the water is not getting to the pan.
If water accumulates inside the freezer, check that the tube leading to the pan on the bottom of the refer is not clogged in some way.
If the water is in the refrigerator side, there may be a hole in the tank for the through the door water dispenser. It would leak everytime the icemaker dropped ice and refilled.
Jan 19, 2009 | Amana ARS2464B Side by Side Refrigerator
Water leaking on floor from under Mod#TPH21PRS;TPH21PBS
I you dont have any water hooked up for the ice maker or for water at the door, about the only thing left is your freezer drain. Look in the back under the freeser side and look for a drain... see where it drains.. over flowing? anyway water could get out from where in drains to?
Aug 21, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
151 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
