Question about Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16
Where can I find stainless steel staples for Swingline
Where can I find stainless steel staples for my swingline stapler?--purpose is to put bunk board carpeting on my boat lift. 3/8''-1/2'' would be preferrable.
I have the same question...were you ever able to find them?
d
Posted on Oct 31, 2011
Swingline model 67 broken staple driver part replacement
you buy a new stapler . they do not make that part as a replacement
Aug 27, 2016 | Swingline 06702 Model 67 Electric Stapler
My staples are stapling backwards.
Take your staples out of your stapler and reinsert new ones.
Try that and see if it makes any difference.
May 07, 2014 | Swingline 74729 747 Business Full Strip...
How do you open swingline tot 50
Here's a video that shows how to open an older Swingline Tot stapler:
Vintage Swingline Tot Stapler Demonstrated
Nov 15, 2011 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
We have a swingline model #690 - after loading with new staples, it does not staple. It is plugged in and makes a sound like it's stapling but does not release a staple.
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Apr 18, 2011 | Swingline Portable Electric Stapler
Swingline 270 (69270) Staple ends are left mostly open Also, stapler makes a significant popping noise with each use
Swingline, now owned by ACCO, should have a service manual that would tell you how to clear jams - here's the url - http://www.acco.com/contactus.aspx#swingline. If not, you can also send them your question directly so they can help you resolve the issue.
Jan 27, 2011 | Office Equipment & Supplies
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
Cant find replacement brads for swingline
the problem was not with a stapler it was with an electric brad nail gun made by swingline , after researching this, my swingline (printed right on the gun) turned into a "powerfast electric nailgun model 32003" which will take arrow replacement 1" brads .
May 04, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16 Logo
759 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Van Allen II
Van Allen II
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
