Question about Microwave Ovens
Whirlpool microwave have a microwave that works but does not heat. can you tell me what part is out
  • Microwave Ovens Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
Whirlpool microwave does not heat
Filter By mh1150xm_1000_watts_convection_m_53389.jpg Problem with:
Whirlpool MH1150XM 1000 Watts Convection / Microwave Oven
1 Points
whirlpool microwave does not heat
Dec 31, 2012 | Whirlpool MH1150XM Convection/Microwave...
Sometimes when I go to heat something in the microwave it doesn't heat but when I open the door and then close it it sometimes will work?
Sounds like the door switch is going bad this is the switch that "tells" the microwave the door is closed so that way it doesn't run with it open
Apr 26, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Whirlpool microwave does not heat. The power is
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 15, 2010 | Whirlpool MH7140XF Microwave Oven
MH1160 Whirlpool Microwave Stopped Heating
Are you getting 110VAC on the primary leads of the high voltage transformer when you press "Start" to begin cooking?
If not, yhen it may simply be a bad cook relay (I do board repair) or a bad bottom or inside top door switch. See http://www.microwavecontrol.com/doorsw.htm
E-mail me via my site for more free help.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 21, 2017 | Whirlpool MH1160XSS Stainless Steel 950...
Our whirlpool microwave does not heat. Everything
Hi!if your microwave does not heat, it only means that the magnetron is not working, try to look for busted fuse. or check the capacitor for leak, the hi voltage diode sometimes malfunction, and if all of the above mentioned are all ok maybe your magnetron is defective.
Sep 15, 2009 | Whirlpool GH4155XP Microwave Oven
Whirlpool microwave doesn't heat
magnatron faulty and Hv fuse needs to be replaced.
Sep 14, 2009 | Whirlpool GH8155XM Microwave Oven
Microwave isn't heating as well as it did. After
The magnatron is weakened and needs replaced. A proper power test would tell how bad but sounds like you are beyond that already. Eric
Aug 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
