Question about Kenmore 5365 Dehumidifier
Control panel lights up-nothing else happens
The fan blades spin freely. the bucket full alarm lights up and beeps. nohting else. is there a replaceable fuse i can check? thanks
  • jogofishing Jun 22, 2008
    I have a Kenmore dehumidifier mod.# 580.53650200. When plugged in and turned on, control panel lights up and reacts to any button pushed. Remove bucket and bucket full light, lights up, replace bucket and bucket full light goes out. Fan will not run, compressor will not run. Fan blade is free and spins freely, no obvious visible problems front or back of display PCB, main PCB, humidity sensor board, thermistor, or capacitor, no disconnected wires, no pinched wires. Please help !
  • steve brown Mar 24, 2009
    lights come on all connections good but the fan and the compressor will not come on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
First check that the bucket is in properly. then remove bucket and push red button with finger with the unit on. if you are still getting a red alarm light it might be time to change the control panel. also unit does not work the same in cold weather. it will cycle too often. unit better used in summer-------good luck
Posted on Dec 18, 2007
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
The Bucket Sensor light is always beeping and the front panel says 01. The machine refuses to work
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Sep 18, 2011 | Kenmore 54501 Dehumidifier
My Kenmore 580.54501 dehumidifier "Water Bucket
heatman101
May 27, 2011 | Kenmore 54501 Dehumidifier
My dehumidifier keeps beeping??????
The water tank is either full or not positioned correctly. Empty the tank and/or make sure it is positioned correctly (should fit perfectly and not bump out from rest of unit).
If you have it connected to the drain directly, your tank may still be filling up unless you have the PUMP button pressed (and PUMP is showing in the LED screen).
Good luck and please rate me.
-mark
May 05, 2011 | DeLonghi DE400 Dehumidifier
Fan does not work
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 16, 2009 | LG Goldstar LD65EL Dehumidifier
Dehumidifiers Logo
248 people viewed this question
Top Kenmore Dehumidifiers Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
