Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
I have the same problem as bergend decribes
How do i fix the magnetic valve???
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
You can`t fix it, it needs to be changed
Posted on Oct 06, 2009
What i have to replace the part in my air con system with this fault code 00256 a/c pressure/temperature sensor(g395)
In front of the firewall there is a plasticcover, also covering the windshield wipers. Remove that.
Underneath, on theleft side of the big box in center there is a magnetic valve with 2 "bulbs" sticking up (the magnets).
There is a known issue that this valve clogs with sawoffs from the engine leaving you with only hot air, or in my case: hot air in the side and defrost vents, and cold air in center.
There is a new valve with the same part number, only ending with a B to fix the issue, however it MIGHT help with a good flush of the cooling system, and removing the 2 "bulbs" and clean it out.
Dec 12, 2014 | 2011 Audi A5
How do you fix stuck valves on a 86 Suzuki gs450l
Instructions
    • 1 Disassemble your engine down to where you will have access to the valve spring. You will need to remove the cylinder head cover, the rocker arms and the push rods. You will also need to remove the spark plugs.
    • 2 pixel.gif Next turn on your air compressor and regulate the air 60-90 psi, turn the crankshaft until the cylinder you are replacing valve seals on is on top dead center. Screw the compression gauge hose into the spark plug hole, attach the air compressor hose, your cylinder is now pressurized.
      The valves will stay in the closed position as long as the air pressure is holding it up.
    • 3 pixel.gif Using the valve spring tool, compress the valve spring and remove the valve keepers with a magnet. These may be stuck to the valve spring retainer and a little bump with the palm of your hand or a small hammer will jar it loose. Pack towels around the area so you won't lose the keepers into the engine. Remove the spring.
    • 4 Remove the old valve seal with pliers or screwdrivers and replace with a new seal. Reverse procedure to reassemble engine, use the magnet when installing keepers and after removing valve spring compressor tap the top of the valve lightly with a hammer to seat the keepers.
Jan 13, 2013 | Motorcycles
Hot water heater pilot will not light
You have red wires connected to bottom of gas control valve?
Is this a power vent model?
What model, what brand water heater?
Is new thermocouple is finger-tight plus 1/4 turn and not shorted against gas control valve?
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Copy following link for safety magnet:
Magnet will click closed when pilot is turned off. Put butane lighter on end of thermocouple and listen for clicking sound.
http://waterheatertimer.org/pdf/Safety-magnet-Gas-control-valve.pdf
Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Bad gas control valve:
Low gas pressure, air in gas line, inadequate air supply, clean the air intake, tripped FVIR system, etc.
Aug 28, 2012 | Water Heaters
Helllo right..i have Acer Cystal Eye webcam
Specially when you're using Windows XP, it happen to me as well.My solution is switching to Windows Vista, it work just fine...
Feb 27, 2010 | Acer Aspire 5610-4648 Notebook
Gas valve clicks but does not light
Hello
The click is either the gas valve opening or the ignitor trying to ignite.
From what you decribe,im going to say you have a bad ignitor.
If the gas valve is indeed opening,then you need igniton to light the gas,
which leads me to say bad ignitor.
Hope this helps.
Feb 02, 2010 | Coleman Propane Forced Air Heater...
The indicator light continues to blink rapidly
you are correct in thinking the problem is caused by the valve. Use a magnet to connect to the valve from the outside of the machine, slide the magnet very slowly upwards along the water level, the rapid flashing should stop and the water should begin to heat, if not try again as you have not connected the valve to the magnet
Sep 08, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo 7814 does not heat water and red light keeps flashing
is the red light flashing as though not enough water, if so use a magnet to connect to the valve inside the machine, the valve can be found along the water level where the float is. what is happening is that the float is stuck. by connecting the magnet to the valve and very slowly moving the magnet along the water level, upwards the valve will follow and the water will begin to heat as the light changes to a slow flash, if it doesn't work try again as you have not connected to the magnet
Aug 26, 2009 | Philips Senseo HD7832 Coffee Maker
Bowflex treadmill code 05
tHIS MAY BE A SPEED LOSS ERROR. Is the belt moving when this happens? Decribe what lead to this problem in the first place that will help me to better assist you.
Mar 30, 2009 | Bowflex Treadmill Series 7
Magnetic vallve
If you try to make a cup of water(tea) and you hear the pump start but no water is comming then you have to replace the magnetic valve.
Aug 17, 2008 | Saeco Royal Professional Espresso Machine
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
118 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
