Question about Microwave Ovens
Hinari microwave doesn't cook
I have a built in hinari EMX650BISSE The display on the front works. I turn the dial until the digi display shows the time i want it to cook. I press the start button but nothing happens. The digi display does the countdown as if the microwave is cooking. The light is supposed to go on inside when you open the door and yet again when its cooking. However the light only goes on when the door is just to say shut...when the hooks in the door have contact within the holes in the microwave body but once you push the door shut so that the hooks have secured the door shut the light goes off and never comes back on.
    Sergeant:
    Champion:
  • 205 Answers
Hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Posted on Sep 25, 2009
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have an hinari 2 shelf microwave, everything is working on it but for some reason it doesn't cook i.e. it doesn't heat anything, any suggestions?
depends on how sentimental u area sounds like the magnitron went out. call your local appliance repair person and ask what he charges for that. usually it is pretty expensivea
Mar 29, 2011 | Microwave Ovens
Have just got second hand Hinari Lifestyle Microwave Mx95TC, No instruction manual with it. How do I set the clock?
I have a Hinari Lifestlye Microwave and also MANUAL!!!!!!
Let me tell you how to set the clock!
First, you press the clock button
Press the cancel button, the display will show 0
Enter the current time in 12-hour format ( this is very important as if you enter an invalid time, the display will revert to 0
Finally, press clock button again!
Nov 18, 2010 | Microwave Ovens
Setting the clock
hello,
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
Hinari lifestyle combi microwave oven. After being stored for some time, this unit displays E=01 and bleeps continually. Can't get past this for it to work.
Hi, I don't have a solution, just the same problem! It says you had one solution to your question but I can't see it any where. Is your hinari working now?
A.I.
Jun 13, 2009 | Microwave Ovens
Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
Hinari microwave sparked and wont work.....
Check the service section in your manual.
You will get any Hinari manual with the manualfox search engine. Check results here:
http://manualfox.com/link/hinari.htm
Dec 15, 2008 | Frigidaire FMV156DC Microwave Oven
Microwave Ovens Logo
199 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
